255/45 r19 instead 245/45 r19
Old Jan 23, 2012 | 10:06 AM
miamijag's Avatar
Default 255/45 r19 instead 245/45 r19
I am going to change my tires 245/45 r19 in the next 6 months. I was thinking about putting different size 255/45 r19 on the original wheels r19. What are your thoughts guys? Will I have problems to install them? Will I have problems with my jag, the way it drives? Or should I stick to original tire size?
Old Jan 23, 2012 | 10:21 AM
miamijag's Avatar
Oops... Original 245/40 r19 , I want to put 255/40 r19
Old Jan 23, 2012 | 10:28 AM
miamijag's Avatar
Sumitomo HTR Z III
Old Jan 23, 2012 | 12:41 PM
duke_dallas's Avatar
You shouldn't have any problems with fit. There's plenty of clearance for a slightly wider and taller tire. Others will probably chime in here that going with a taller tire is going to wreak havoc on you ABS, traction control, etc., but it won't. The 255/40 just a little over 1% taller which is well within the range considered safe in the wheel and tire industry.
Now, your speedo will be slightly off. You'll be travelling a lil faster than the speedo reads.
Old Jan 23, 2012 | 02:34 PM
miamijag's Avatar
Thank you , I want them to be little bit wider
Old Jan 23, 2012 | 03:02 PM
bryce804's Avatar
Originally Posted by miamijag
Sumitomo HTR Z III
Have you ever used these tires before? I have used them on a previous car and I wasn't happy with them at all.
Old Jan 23, 2012 | 03:10 PM
miamijag's Avatar
What did you not like in them?
Old Jan 23, 2012 | 07:14 PM
jagular's Avatar
Also, why wider? Ten mm is very tiny and you will not notice any difference in appearance. In fact, 10 mm is within the normal tolerance for both sizes in terms of actual measured tread width. The tires may in fact be the same width with those different sizes stamped on the sidewalls.
Old Jan 24, 2012 | 03:46 AM
bryce804's Avatar
I did not like them due to the road noise they create. I feel as I had other problems with defects and balancing problems, but its also been 6 to 7 years since ive used them.
Old Jan 24, 2012 | 08:47 AM
jagular's Avatar
Sumitomo owns the Dunlop brand. They can make very good tires if they choose to. They can also make cheap and nasty tires if anyone wants to buy them.
Old Jan 24, 2012 | 09:35 AM
miamijag's Avatar
Continental ExtremeContact DW 255/40 r19 ?
Old Jan 24, 2012 | 06:13 PM
jagular's Avatar
Excellent all weather tire. I have the full winter version on my SAAB Aero and they are superb.
Oops, continental nomenclature caught me out again. DW does mean Dry Wet. All weather version is the DWS. With the S for Snow of course.
The really high performance Contis are the contact 2, 3 and newest 5P
These also get high ratings in the press and from users.
Old Jan 25, 2012 | 10:00 AM
miamijag's Avatar
On the tirerack they are as max performance summer tires
Old Jan 25, 2012 | 10:12 AM
They definitely are not an "all weather" tire.
DpezXK8
Jan 13, 2015 05:44 PM
rp2427
Sep 21, 2014 12:12 PM
Mfieldpreecher
Mar 9, 2014 05:43 PM
'00XK8
Dec 9, 2012 07:56 PM
1999XJR
Mar 30, 2012 01:47 PM
