6mm or 8mm timing chains
Old Jul 27, 2017 | 11:49 AM
TXFireblade's Avatar
Default 6mm or 8mm timing chains
I've been reading about various timing chain issues with the 5.0 engine across the forums and it seems like these parts have been increased in size from 6mm to 8mm sometime around 2012.
If anyone has access to the XF parts information, can you tell us at what VIN# the 8mm cam chain was introduced?
Thanks in advance.
Old Apr 29, 2018 | 07:21 AM
jahmezis45's Avatar
Did you ever get the information your were looking for? I am about to change my timing chains as well
Old Apr 29, 2018 | 09:27 AM
clubairth1's Avatar
Community Influencer
Not really any more help but I have heard that 2013 cars after S/N B52041
came with the updated timing chains/gears.
Note that B serial numbers are "I think" XF numbers?
I have a 2014 XJR and it has a "V" serial number so I think my car does have the later system.
Your right that looking at the part numbers would be the best way to see the changes.
Old May 5, 2018 | 09:18 PM
davetibbs's Avatar
I've been looking into this a lot with my rebuild. While I can't tell you what VIN# they changed the chains, I can tell you that mine came with 6mm timing chains, and replacement 6mm parts are becoming very expensive. I suspect this is because a certain number were made - not of course anticipating the failure of earlier cam chain guides, and requiring dealers to replace only the chains and guides (and therefore stick to using 6mm chains/VVTs even though they had been superceded), resulting in depleted parts supplies.
However, if you're willing to replace all the timing parts: chains, crankshaft sprockets, tensioners, guides, and all 4x VVT units (total cost of parts is around $1500ish if you're lucky) then it's possible to replace all the timing gear for 8mm. Given I feel like I'm "all in" with my rebuild, this is the route I've gone down, so I've ordered 4x new VVTS and a set of chains/tensioners/guides etc for a Range Rover Sport. This significantly reduces the cost vs ordering the Jaguar equivalents, but the parts are the same.
Old May 6, 2018 | 06:54 AM
clubairth1's Avatar
Sorry the "B" serial numbers are from the XK model NOT the XF!
Old Jun 21, 2018 | 12:27 AM
CanadaXFR's Avatar
Hi any one know what vin they changed to 8mm timing chains? For XFR’s as I have a 2013 and know that’s around the time they changed things. I’m guessing they brought thoose changes over when they went to 8 speed autos etc. hope someone knows!
Old Jun 21, 2018 | 11:03 AM
clubairth1's Avatar
No I am still looking too and I think the change was done at the same time on all 5.0L V-8's regardless of what car they were installed in.
But just a guess.
Old Jun 21, 2018 | 11:25 AM
CanadaXFR's Avatar
I contacted My local jag dealer with my vin and he said I have 8mm chains. VIN MS85831.
Old Jun 22, 2018 | 11:10 AM
clubairth1's Avatar
Any idea on the build date of your car?
Thanks for the serial number too.
Old Jun 22, 2018 | 11:19 AM
CanadaXFR's Avatar
February 2013. Hope that helps some! Could have switched over to 8mm a few months earlier I’m not sure 🤔
