8 mm bolt with nut.
Old Sep 25, 2020 | 04:54 PM
Chris Brister's Avatar
Default 8 mm bolt with nut.
Just recently pulled and replaced my injectors on the driver side of my 2010 XFR. Pulled the coolant expansion tank off. After putting it back together I have a stray bolt and nut combo. Any ideas as to where it goes?
Old Sep 25, 2020 | 08:59 PM
Richard Zuniga's Avatar
yea just dump it into the oil fill opening and you should be good
nah jk dunno man
wierd that you'd have something left over
Old Sep 26, 2020 | 09:17 AM
Six Rotors's Avatar
The parts manual lists a M8 x 80mm( about 3.25in long) stud for the fuel rail to head fastener. There is no picture showing where.
Old Sep 26, 2020 | 09:22 AM
Seems like it might’ve come from around there but it has 4-10mm holding it down. Not sure if that’s what you’re talking about.
Old Sep 26, 2020 | 09:26 AM
This one is exactly 80mm. It’s got about a 2.5 inch shank. Can you drop the parts manual if you have it?
Old Sep 26, 2020 | 09:33 AM
I took several things off in order to get to the injectors. I labeled each bag. It was in a bag labeled coolant reservoir but couldn’t find where it went.
Old Sep 26, 2020 | 09:36 AM
Also pulled this off and haven’t put it back on because I haven’t got to the other side yet.
Old Sep 26, 2020 | 10:40 AM
Six Rotors's Avatar
Go to the X350/X358 forum, in the Sticky Threads is "X350/X358 How To quick links", in the first post you will find Jaguar Electronic Parts Catalogue full download and install instructions.
Dell Gailey
Jun 20, 2021 11:04 AM
Johnken
Jun 16, 2019 12:10 PM
jamdmyers
Mar 15, 2015 02:00 PM
vandenplas408
Jan 8, 2014 01:52 PM
Gergs
Nov 8, 2010 07:18 PM
