air intake damage
Old Mar 28, 2022 | 06:41 PM
iownme's Avatar
Default air intake damage
the metal part of the air intake where the plastic intake attaches to the throttle body is broken. is this an issue or common?
Old Mar 28, 2022 | 07:37 PM
Swilmer52's Avatar
I had the same issue with my 2013 XF, it’s the 5.0 supercharged model. I replaced my intake with a Mina Intake, that was my solution.
Old Mar 28, 2022 | 07:45 PM
iownme's Avatar
damn... i just bought 2 regular style k n n air filters to go in the airboxes, now i see mina has an intake which takes open air filters.
i have the 3.0
the v6 mina intake is affordable too....Grrrrr
Old Mar 28, 2022 | 09:00 PM
OzXFR's Avatar
i have the 3.0
Lots of debate and discussion over the years about Mina intakes, cone filters / supposed CAI, K&N v stock filters etc and the bottom line (and supported by my experience across XFR and F-Type) seems to be:
- for a system like that fitted to the XF with the airboxes in the engine bay fed by intake snorkels under the leading edge of the hood/bonnet, a cone filter set-up like the Mina one does not improve power/torque/horsepower at all and most probably reduces all of them as it turns out to be a "hot air intake".
- but it does release a sizeable whack of SC whine (due to the deletion of the stock Helmholtz resonators).
- K&N air filters also make zero difference to hp, torque or performance as they flow no better than the already very good stock filters.
- however on a system like the F-Type and XKR with the airboxes mounted low down behind the front wheels, replacing the stock airboxes with cone filters doesn't reduce power/torque/performance and possibly improves all of them slightly, and you get a big increase in SC whine (I have the Mina lower intake set up with cone filters on the F-Type but the stock upper intake set-up).
kevh
Jan 14, 2021 09:08 PM
gimli
Jun 10, 2019 07:45 AM
max224
Nov 28, 2015 07:57 AM
Justink201
Apr 3, 2015 10:09 AM
phaelax
Apr 17, 2011 08:49 PM
