Another problem occurred on my XF
Old Sep 25, 2011 | 07:18 PM
Watchgeek's Avatar
Default Another problem occurred on my XF
The passenger side rocker switch closes the window but the same switch does not work when you want to open it.
Can you give me ideas on what the problem is?
Old Sep 26, 2011 | 11:59 AM
Blackcoog's Avatar
It's the switch. I'd assume the driver's switch operators it normally right? If so then replace the passenger switch.
Old Sep 26, 2011 | 04:25 PM
Watchgeek's Avatar
Thank you....will they have to takenthe door apart to replace switch?
Old Sep 26, 2011 | 07:16 PM
jagular's Avatar
Not usually, they are mounted on the door pull or door card? If so then they should just pop out for replacement.
Old Sep 26, 2011 | 07:58 PM
cwood's Avatar
An ECU reboot might be worth a try? Highly unlikely but you never know with all the electronics in these things. disconnect the positive side of the battery for 30 secs.
Old Sep 27, 2011 | 06:53 PM
jjsaustin's Avatar
Disconnecting the battery is not worth even trying.
I assume the window motor is not making any noise when you try to open it? If so, it is likely the switch or less likely a loose wire.
toronadomike
Jan 22, 2026 10:13 PM
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
Razor
Aug 28, 2019 08:34 PM
vsol
Aug 29, 2018 09:46 PM
