Anyone use a handheld tuner for xfr?.
Old Nov 23, 2020 | 05:54 PM
Enzo Valetti's Avatar
Default Anyone use a handheld tuner for xfr?.
So I've been looking around the internet to make my 510 horsepower engine more powerful seems you can get an ECU tune for about $1,500 but then I see handheld tuners for about $300 for a stage 3 I would like to know if anyone has used the plug in handheld tuners and do they work before I spend $300 I want to know if it works I have a Corvette also and I have used a Diablo handheld tuner and it worked great so I don't know if the Jaguar has one as well anyone can recommend I live in the United States so maybe someone can give me a little idea I just don't want to spend $1,500 when I can spend less and still get extra horsepower please let me know your thoughts
Old Nov 26, 2020 | 12:21 AM
AlexJag's Avatar
Sponsor
If your in the States I do tuning on jagaurs xk Xkr xf xfr xfrs models. Send me a pm to discuss.
Old Nov 26, 2020 | 09:37 AM
H.Jones's Avatar
To answer your question, I have used a handheld tuner for my XFR-S, and it works great switching between different tunes, and to switch back to stock, when I was still taking it to the dealership for its annual service, but no longer necessary, as the warranty ended as of September 2020. I would say well worth it for the convenience alone.
Old Nov 26, 2020 | 10:31 PM
Porkchopcash's Avatar
Can you give some more info on your tuner and which one you used.
I have XFRS and wasn't sure it was worth it to have tune alone. It runs like a beast now.
Did you notice difference? Appreciate if you could share your experience.
Old Nov 27, 2020 | 09:34 AM
H.Jones's Avatar
Search is your friend, I documented my progress pretty thoroughly, this is one of the many threads I had started: https://www.jaguarforums.com/forum/x...-xfr-s-189086/
Tune alone isn't worth it on our XFR-S, given you're starting at ~550HP (542 to be exact)... Most tunes will get you to ~570 to ~600HP (depending on the tuner). You will not notice a significant difference 20HP on a 500+HP car that weighs as much as our cars do, will not be that noticeable, 50HP should be, as you're approaching that 10% figure.
I did mine in stages, I did the tune and upper pulley at once, as that was a route I had taken before with my 2012 XFR, I eventually upgraded my tune to a Velocity (in lieu of Rica), and went with custom, high flow CATS, if I had to do it over, I would probably do just the lower (crank pulley), high flow CATs, and CAT back exhaust (more for sound than power) with a Velocity Tune, I guess I wouldn't do the upper pulley, in my opinion its not worth the hassle and is non-reversible... I had the opportunity to do a couple of 1/2 mile events with another local XFR-S owner, who ran his car stock the first time (where I clearly walked him every single time), and then ran it with lower pulley and tune, and the difference between us was negligible...
Old Nov 28, 2020 | 12:36 PM
AlexJag's Avatar
Sponsor
You will notice a good difference on xfrs as well, and especially if you got the upper pulley, Tune is still needed. I can help if your in the within reasonable area for shipping.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Nov 28, 2020 | 01:39 PM
dennis black's Avatar
20 Year Member
you should get the lower crank pulley because the top one slips ,youll get 3.5 pounds of boost also easier to install in a hour or less
Old Dec 1, 2020 | 08:44 PM
wimmer's Avatar
big fan of the lower pulley as well, went with euro tune stage two thinking next maybe better cooler and upper pulley, thoughts?
Old Dec 8, 2020 | 05:57 PM
20 Year Member
do not get upper pulley
Killbox
Oct 21, 2022 06:36 AM
BrianXF12
Dec 12, 2020 04:32 AM
Enzo Valetti
Jan 22, 2020 04:04 AM
EdgyXFR
UK & Eire
Feb 1, 2018 01:06 AM
Shahin
Jul 29, 2011 02:29 PM
