Anything else to do while changing brakes? '11 XF SC
Is there anything else I should be doing while I have the brake pads changed (to ebc Yellowstuff at 52k miles)? I'm genuinely tempted to use the reds because of my body color (caviar), but been running yellow for many years with great success on various vehicles. Rotors should be ok I think but we'll see. Lines are braided if I'm not mistaken. Thanks!
Check the caliper slide pins for brake dust, dirt and grit on them (and inside the sleeves they sit in), after 7 or 8 years possibly unchecked they might be a bit mucky and when they get too much crud on them they can seize.
I always remove these pins anyway as part of the pad replacement method, so I clean them off (and the insides of the sleeves) and apply a very light coat of brake grease to them. Some say you shouldn't grease the slide pins as that will just attract dust and dirt but I have greased them for 30 odd years and never had a problem. Make sure you use proper hi-temp ceramic brake grease though.
Also apply the same brake grease to the backs of the new pads and any place where the pads contact the caliper, eg right on the ends of the pads.
Last but not least, check the backs of the rotors for wear not just the fronts, you might be surprised how much more the backs are worn compared to the fronts.
The theory is that the backs of the rotors (and the inner pads) wear a lot quicker than the fronts and the outer pads as the brake pistons bear directly on the backs but only indirectly on the fronts. Whether or not this theory is correct I have always found more wear on the backs than the fronts.
I'd also suggest the reds which work very well on the street
While you have the wheels off - would prob do rotors as well (I like the drilled and slotted look like R1 Concepts). I would spray the calipers (I found high temp brake/caliper paint to be excellent / did mine 3-4 yrs ago and still perfect)
Beyond that it's pretty quick and easy to spin off the wheels and brakes so not sure there is a lot more to do at the same time
RobinGa
Oct 25, 2016 07:05 PM
mcm97
Apr 2, 2014 12:06 PM
dneider
Aug 22, 2010 02:24 AM
FullThrottle--->XJR6
May 3, 2010 12:35 PM
