Bad fuel injectors
Old Mar 18, 2016 | 11:57 AM
rlembach's Avatar
Default Bad fuel injectors
2012 XF Portfolio 45,000 miles. Had it to dealer to fix broken rear camera cable and intermittent misfire. Sometimes the misfire was barely noticeable at idle and other times at idle you could see the tach needle fluttering. At first they said they did feel the miss but there were no codes or check engine light. When I went to pick up the car it started missing more and it did set a check engine light. They have had the car for a week and Jaguar technical advisory has authorized them to replace 2 fuel injectors. Has anyone else experienced failed fuel injectors? The service rep said they cost $1,200 each. Thank goodness for warranty.
Old Mar 18, 2016 | 01:26 PM
Busa's Avatar
Even in English money that's a lot of money just for the injectors. Stunned !
Old Mar 18, 2016 | 06:19 PM
DPK's Avatar
DPK
A can of this into a full tank every 5000 miles should keep the injectors working properly..whole lot cheaper too..
Old Mar 19, 2016 | 07:58 AM
rlembach's Avatar
Picked the car up last night and it seems to be idling OK. dealer did not have the service paper work ready for me when I picked up the car and I couldn't wait for it. They will mail to me. I suspect that it will only say that they replaced 2 injectors but since it was under warranty it will not list any dollar amounts. If there is anything notable I will post.
Old Mar 20, 2016 | 08:23 AM
newXF's Avatar
Rlembach, are you able to get any more detail from your dealer on the cause of the two failed injectors, and the condition of the ones that weren't replaced? Did they perform any type of cleaning on the remaining injectors? Carbon buildup on the injectors has been a serious issue for some of the earlier direct injection engine designs, resulting in misfires, loss of HP, etc.- well documented in other brands, but there hasn't been as much reported for JLR (https://www.jaguarforums.com/forum/x...charged-94489/). It would be great to know whether or not Jaguar will be covering these issues under original and/or CPO warranty. Thanks very much for posting.
Old Mar 20, 2016 | 09:14 AM
Mikey's Avatar
I'd be interested in learning too. Defective injectors on these cars is not commonplace.
The $1200 per unit Jag warranty price doesn't surprise me. The aftermarket will drive that down to $100ish ea. like it has on most other cars
Old Mar 20, 2016 | 10:51 AM
kwiksilver's Avatar
I understand that this product is good, but I have not used it. I have used another product with excellent results - Redline Complete Fuel System Cleaner. It costs about $12 for a 15oz bottle, but only a couple of ounces to a tankful every once in a while works great. I add it to every 4th fill up.
Old Mar 20, 2016 | 11:45 AM
DPK's Avatar
DPK
You're right, Redline SI-1 is a great product and I use it also..It is less aggressive than the BG 44K is and can be used every tank if you want with excellent results..I use a whole bottle every other tank full and the BG 44K once in a full tank every 5000 miles as recommended by my Jag tech buddy...
I've used these two products ever since 1992 when I bought my 300E Mercedes and the Mercedes tech then told me it was like a shot of penicillin for the fuel system...I have never had a fuel system issue.
Old Mar 21, 2016 | 06:34 AM
rlembach's Avatar
I did not get any details on the reason for the failure. I doubt that they could tell why they may have failed. Before replacing them they did an injector cleaning to see if that would fix the problem, but it did not. The repair was covered under warranty.
Old Mar 21, 2016 | 09:06 AM
Mikey's Avatar
Then it is unlikely that any additive would prevent or cure such a situation.
Old Mar 21, 2016 | 11:12 AM
rlembach's Avatar
They tried the cleaning to see if that would cure the problem because that would have been a cheaper alternative!
Old Mar 21, 2016 | 11:54 AM
DPK's Avatar
DPK
Obviously it had worked in the past for them, as I've heard the same...unfortunate it didn't work for you..glad it's purring again for you.
Old Mar 23, 2016 | 10:47 AM
rlembach's Avatar
Unfortunately the "purring" didn't last too long. Got a check engine light last night so it is going back to the dealer today.
Old Mar 23, 2016 | 10:57 AM
DPK's Avatar
DPK
Aww man..that sucks..Hope it's something simple..
Old Mar 23, 2016 | 11:05 AM
newXF's Avatar
Sorry to hear it rlembach. It may be worth asking the dealer if they will be checking on the condition of your intake valves- if you're experiencing misfires due to carbon buildup, these are likely to be impacted as well. As far as I know, it's not at all clear what JLR will or will not cover under warranty in terms of inspection, cleaning, and repair for DI related engine problems. Hopefully you're experiencing something with a more straightforward fix (I'm assuming they've already checked on the widespread water pump issue). Please keep us posted!
Old Mar 23, 2016 | 11:38 AM
kwiksilver's Avatar
Hmmmm. Plugs/coil packs?
Old Mar 31, 2016 | 11:07 AM
rlembach's Avatar
Here is the update. It was an oxygen sensor. The bad thing is, this dealer never has any parts in stock. Supposedly when they ordered the part, the part they received had the correct part number on the box, but the wrong part was in the box, s it had to ordered again. To complete this entire repair, starting with the rear camera cable, check engine light for bad injectors and check engine light for oxygen sensor, took the dealer a total of 16 days. I think that is totally ridiculous, but you are at their mercy. At least they provided a loaner car for the entire time.
Old Mar 31, 2016 | 12:36 PM
DPK's Avatar
DPK
So it's all fixed up now?..What kind of Loaner..was it an F type?
Old Apr 1, 2016 | 06:31 AM
rlembach's Avatar
Usually it is a 4 cylinder XF turbo. That car is horrible. The turbo lag is bad and the interior can't even compare to a Honda Accord. This time I got a Range Rover Evoque. It was much better than the 4 cylinder XF. These are not dealer owned cars. They pay a rental car agency about $68 per day. So this whole affair cost the dealer about 1,100 in rental car fees!
kmmoore1013
Feb 28, 2016 06:37 AM
Flyboygus
Feb 27, 2016 05:28 PM
bob peers
Feb 27, 2016 08:20 AM
tberg
Feb 24, 2016 10:59 AM
Pilotman11
Feb 24, 2016 05:34 AM
