Boot unlocking problem
Old Jun 1, 2015 | 06:40 PM
whyhellothere's Avatar
Originally Posted by Mikey
No. This post relates only to the button not working and the trunk/boot not opening.
Are you serious?
All these issues points to another issue of securing the vehicle (auto lock)
The button not working is also related to the questions I asked.
Anyways, this forum has helped plenty, and plenty. I dont know why you would contribute to pushing off my concern to another page when this can clearly cover it.
Old Jun 1, 2015 | 08:30 PM
Mikey's Avatar
Originally Posted by whyhellothere
Are you serious?
AFAIK, a defective trunk lid button will not prevent the car from locking or set a 'trunk open' warning.
Old Jun 2, 2015 | 12:54 PM
There's harness links to the boot button, that is also connected to the electronic latch. Any of these wires can trick the on board system to throw those messages off, but then again the title for this post is Boot Unlocking problems, not necessarily just for dead button.
Old Jun 2, 2015 | 05:05 PM
Mikey's Avatar
I'd guess that your problem is more related to the switch/sensor that detects the position of the trunk lid. It thinks the trunk is open and won't let the 'autolock' function work.
Old Sep 29, 2019 | 10:59 AM
farhad4uk's Avatar
I have the same problem, but revese. I can ope it with the key none of other system work anymore. I can not fine the fuse for it either. It a XF 2009 Pre-Lux 2.7 L
Old Jul 11, 2020 | 12:51 PM
Tagrep's Avatar
Default Did you sort it?
Hi. I have the same problem as you, manual opening works but all electronic openers not operating the lock mechanism, boot light comes on when buttons pushed or lock opened manually.
did you manage to find a cure for it or a fuse? Thanks
Old Jul 11, 2020 | 02:00 PM
Richo's Avatar
Default Boot unlock problem
hi what I done on mine was change the locking latch. I got one on eBay which was labeled genuine, it’s been a while now and it still works and it’s so easy and straight forward to fit
Old Jul 11, 2020 | 02:28 PM
  #28
Tagrep's Avatar
Thanks, I was thinking it was the latch so will try and source a replacement.
Old Oct 24, 2020 | 04:11 PM
Frederick Whitfield's Avatar
Default Boot unlocking problem
Originally Posted by jagular
The boot catch is electronic. If you can open the boot at all then the electronic latch is working. The problem with the boot lid switch may be broken wiring at the boot hinge rather than the boot lid switch itself. Does the metal emergency key open the boot lid when you turn it in the mechanical lock concealed by that rubber blanking plug?
plug does not work when pushed
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
D.K
Dec 10, 2023 02:05 AM
MrMellor
Sep 7, 2015 10:22 AM
Bigvettefreak
Sep 6, 2015 04:27 PM
