Bosch "010" charge cooler pump upgrade and ?'s
Old Jun 9, 2018 | 07:05 PM
Adam J's Avatar
Default Bosch "010" charge cooler pump upgrade and ?'s
hi all, just swapped out the charge cooler pump today to the upgraded Bosch unit per other useful "how to" posts on this forum.
wanted to show couple pics of how i did it in case it saves anyone some time
also wanted to ask if anyone has info on operation and how/when the car sends power to this pump and if it runs 100% / if it can run 100% of the time.
so i raised up front of car and put jack stands under for safety.
i removed my engine under tray a year ago and it's never gone back on..
removed a few fasteners in each wheel well and a couple on the front undertray plus the ones in engine bay to swing front clip off to the side.
i put a rolling cart of appropriate height under the front clip and just rolled it off to the side, not even needing the wire harness for the front parking sensors to be disconnected.
so the "trick" for the pump swap is vice grips. so as not to damage the hoses with the teeth of the vice grips, i cut a piece of 3/4'' plastic pipe in half and used 4 "halves" to both protect the hose and make for a nice tight seal. doing this required no draining and refilling of the charge cooler loop. the amount of coolant lost was simply the volume in the pump plus a few inches of hose and easily absorbed by 3 or 4 paper towels.
wiring completed as per parts list in BW's post and swapped the upper rubber mount to new pump. New pump is larger diameter than old, so need to stretch it over. for lower rubber "mount", didn't like it, even after trimming, as i wanted to use the factory spring hose clamp again. discarded the lower rubber mount, connected hoses, released vice grips and inserted a 3'' long piece of rubber heater hose as a wedge where the lower mount used to be. seems to eliminate any nasty shaking / vibration about same as factory mount setups.
got it back and ready to drive. test drove. seemed like a nice and consistent acceleration in each gear through the hills.
the reason for the upgrade was i felt like sometimes by acceleration felt like the supercharger had been removed and other times like all was normal.. i took it to a track a month ago and on lap 2 i had restricted performance for remainder of the session, which was the first time i'd personally experienced this. i have just over 85k miles and sounds like the pump was probably performing in a lackluster fashion.
now time to find the drag strip again and see if the pulley, tune and intake valve cleanings were worth the effort or not.. !
if anyone can provide details on the operation and timing of this pump's energization, I'd greatly appreciate it.
Attached Thumbnails Bosch "010" charge cooler pump upgrade and ?'s-resized_20180609_104644.jpeg   Bosch "010" charge cooler pump upgrade and ?'s-resized_20180609_101805.jpeg   Bosch "010" charge cooler pump upgrade and ?'s-resized_20180609_112210.jpeg
Old Jun 10, 2018 | 02:24 AM
Bigg Will's Avatar
Key on the pump runs 100% of the time.
Old Jun 15, 2018 | 12:14 AM
Twiztidunreal's Avatar
Does it run at 100% flow while the car is on, or is that variable? I know the pump is always on when the car is, just don't know if the flow rate varies or is constant.
Old Jun 15, 2018 | 05:30 AM
Bigg Will's Avatar
KO = 100% on, and 100% flow.
Old Aug 14, 2020 | 03:03 PM
Jaizero's Avatar
In case someone stumbles across this post like I did...
On my 2015 facelift XF 3.0L AWD the supercharger pump does not operate unless the vehicle is running. With only accessory on, there is no voltage at the fuse and the pump does not run. Start the car and 14.5v at both the fuse and pump plug.
Old Aug 15, 2020 | 04:16 PM
blownsilly's Avatar
what size are the hoses that go to the pump and the heat exchanger?
Old Aug 18, 2020 | 02:12 PM
Jaizero's Avatar
I know we're bringing this back from the dead slightly.. After you replaced the pump, how did you bleed the intercooler system?
Old Aug 18, 2020 | 03:09 PM
AlexJag's Avatar
Sponsor
It's It's the same on '08 XKR. Took me a while to figure out that it will not run unless the car is on. I do want to rewire it though so it's on with ignition on, But I suppose battery drain would be severe so maybe it's better just to install a switch
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Aug 18, 2020 | 04:49 PM
clubairth1's Avatar
Community Influencer
I changed my inter cooler and did not bleed it.
Just put the car thru a few heat and cold cycles and it bled itself.
The two cooling systems share a bleed hose to the top radiator tank.
Here is Jaguar description;
Old Nov 10, 2020 | 08:54 AM
sergt's Avatar
Default 2015 jaguar xfr aux pump
Did you ever figure out what the third wire is for. I am looking to do an upgrade on my aux pump also but the bosch pump is only 2 wire and I am a little bit confused about the third wire?
Old Nov 10, 2020 | 12:24 PM
Jaizero's Avatar
Yup. You only need two of the wires +12v and ground. There is a third wire (yellow if I remember correctly) that I didn't use and just wrapped up in the newly made wiring harness. Just take a volt meter and figure out which one is positive and which one is ground then only use those. The pump operates normally with just the two wires. One thing to point out, the Bosch pump flows significantly more fluid than the old pump does so the outlet hose from the pump will feel very solid as the pump is trying to push a lot of fluid through very small hoses at the top. Also, the rubber mount at the bottom of the old pump will not work on the new pump without heavy modification.
I have a working stock 3 wire pump if you're interested. I ordered it after I found out the Bosch pump was only two wires but never used it as I figured out the wiring for the new Bosch pump.
Old Nov 11, 2020 | 08:27 AM
Jssaab's Avatar
ANy thoughts of the need for the third wire?
Old Nov 11, 2020 | 08:36 AM
Jaizero's Avatar
The third wire is not needed. After the install I had no set/pending codes and still have none. My gut tells me the wire is some kind of sensing wire that looks for a short in the circuit in case the pump fails. The car doesn't care if the wire is used or not so it clearly doesn't care about an open on the circuit. I just wrapped the wire up in the new loom I made in case I ever decide to go back to the factory style pump. Like an idiot I threw away the original plug so I'd have to source a new one of those if I ever went back.
Old Nov 17, 2020 | 01:17 PM
Oxidizer2k's Avatar
Are there any pictures of how the wiring was done? I’d like to do this upgrade but have no idea on how to do the wiring.
Old Nov 17, 2020 | 01:36 PM
Jaizero's Avatar
No, I didn't take any pictures. There is a post on this forum that has a parts list. You need two special Mercedes Benz wires, and a special plug to fit the pump.
This is the post with all the part numbers - https://www.jaguarforums.com/forum/x...pgrade-152574/
Old Nov 17, 2020 | 01:49 PM
Oxidizer2k's Avatar
Thank you!
Twiztidunreal
Feb 3, 2018 12:08 AM
domkacz
Apr 14, 2017 03:38 PM
Jrp79
Feb 28, 2017 02:02 PM
rasputin
Feb 13, 2014 10:40 AM
ccfulton
Apr 15, 2013 11:07 AM
