Which brake pads
Old Dec 11, 2017 | 09:40 AM
garytaylor9's Avatar
Default Which brake pads
Hi What brake pad do I need for my 2008 xf 2.7 as I have just been told by the mot station they will need to replaced soon. Is there a brand I should look for? and what can I expect to pay for a front set. And should I get the backs done at the same time.
Thanks in advance for you help
Old Dec 11, 2017 | 10:01 AM
jimjpoole's Avatar
Just replaced my pads and discs with Ferodo and they are excellent and I expect OEM.
I bought them from here: https://brakeparts.co.uk/shop/Jaguar...%20and%20Drums
Old Dec 11, 2017 | 11:50 PM
Kapium's Avatar
I recommend EBC Redstuff if you want performance street brakes with low dust. Very good brakes and your car should like them since they're made in England.
Old Dec 12, 2017 | 03:14 PM
ATFS13XFR's Avatar
I put EBC Red Stuff brakes on my car about two months ago and I like them. They aren't 100% brake dust free, but they what little dust does accumulate can be quickly and easily wiped away. As far as performance, they are noticeably better than the metallic pads that were on the car before I replaced them, and also the metallic ones left about three pounds of dust on the wheels if I even looked at the brake pedal once.
I will say that during the break-in period they were a little squeaky, but that soon disappeared. However, as it's been getting colder here the squeaks have returned, but I attribute that to the simple fact that ceramic pads just need to be warmed a little work optimally.
Overall, for the price I think they were a good choice.
Old Dec 12, 2017 | 06:27 PM
BritCars's Avatar
Did you do the final pad bed in process that EBC recommend for red stuff? After I think it's 300 or so urban miles (or more on the highway) you need to do a series of 60mph to about 20mph hard braking stops. That is supposed to do the final bed in and help avoid squealing
In addition some lube on the back of the pad where it touches the piston can help
Old Dec 12, 2017 | 07:17 PM
nsl1's Avatar
Powerstop Evolution Plus Pads - No noise - No dust - Initial bite not as pronounced as OEM semi metallic but they stop just fine and i'm still amazed at how low dust these are compared to the OEM's - Wish I made the switch years ago - would have save a lot of time cleaning wheels - and they seem to be easy on the rotors - Rotors still look new - no lip after ~15k miles. Still plenty of pad life left too .
Old Dec 12, 2017 | 07:54 PM
OzXFR's Avatar
+1.
I put them on my old XFS (355 mm front and 326 mm rear) and they were great!
Problem is they don't make them for the 380 mm front or 376 mm rear brakes.
Old Dec 12, 2017 | 08:06 PM
ATFS13XFR's Avatar
I haven't done the 60-20 hard brakes yet, might try that. Honestly it's not too bad, it only squeak a little when no brake pressure applied, and only for the first mile or two until the brakes have been used a few times.
Old Dec 12, 2017 | 09:26 PM
harryf's Avatar
Any suggestions on Rotors? I used to buy PowerStop slotted and drilled rotors and Akebono Euro Ceramic pads for my S-Type. Very little dust, though it wears the rotors.
I'm looking for great stopping power and no dust. What are your recommendations? 2012 XF Portfolio.
Old Dec 12, 2017 | 09:57 PM
OzXFR's Avatar
Never used them myself but lots of XF owners on this forum are very happy with R1 Concepts rotors. They do plain, slotted, drilled or both (I think!).
Old Dec 14, 2017 | 07:45 PM
BritCars's Avatar
R1 Concepts has a 10% off sale until Christmas. Put in code FF10 They emailed me today
Old Jan 1, 2018 | 06:27 AM
leadfoot4's Avatar
I replaced the pads/rotors on our '09 XF Luxury, a couple of years ago. I went with Beck Arnley replacement rotors, and Power Stop ceramic pads. Good braking performance, and VERY little pad dust.
Old Jan 7, 2018 | 10:17 AM
Kapium's Avatar
They shouldn't squeak if they have lubricant applied properly at install. I've used them on many vehicles and have never had an issue. Did my XF about 9000 miles ago and no squeaks. I use this stuff by Permatex.
Old Jan 7, 2018 | 06:45 PM
lotusespritse's Avatar
The main contribution to dust on the wheels is the rotor being worn off. That is why Porsche as stated in the new issue of Car & Driver is putting on a coating for the steel rotors to prevent the dust.
If your Akebono's aren't producing dust, they aren't wearing the rotors.
I have always had greatly reduced wear on steel rotors from true ceramic pads like Akebono and Powerstop compared to OEM semi-metallic pads. And that makes sense. What you said doesn't make sense.
Old Oct 13, 2022 | 08:41 AM
NavyGuy's Avatar
I know this is old, but for future readers, I think you mean pads. The pads are what makes dust. I mean the rotors do wear a smidge, but all that dust is black not silver lmao.
JimC64
Sep 22, 2025 02:52 PM
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
bklynchris
Oct 25, 2016 01:14 PM
hmaster1
Oct 3, 2016 11:26 AM
JimC64
Feb 13, 2014 07:35 PM
