Brake pads front
Old Aug 28, 2013 | 12:06 PM
Ness925's Avatar
Default Brake pads front
HEY guys,
which front brake pads do you recommend for 09 xf s/c thanks
Old Aug 28, 2013 | 01:15 PM
Blackcoog's Avatar
This thread is helpful: XF and XFR ( X250 ) - Page 2 - Jaguar Forums - Jaguar Enthusiasts Forum
The pads I used in mine are listed in this post: https://www.jaguarforums.com/forum/x...e2/#post785912
Unfortunately I'm not happy with the rears. The pad isn't scraping the entire rotor surface on both rear rotors. I removed and inspected the pad on one side and I couldn't figure out why. The pad must be tipped slightly. I may pull them again to check the shim plate for something that could tip the pad sightly (rivent, bump, etc). After a week the pads burned through some of the material and are finally starting to scrap the entire rotor.
The fronts are perfect. The dust all around is near zero which is a huge improvement over the stock pads. The stock pads did grab better in my opinion but I'm happy with the trade off.
Old Aug 29, 2013 | 09:42 AM
Executive's Avatar
Oem
H20boy
Dec 24, 2024 03:23 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
JagLove86
Sep 6, 2015 10:36 PM
