Brake pads front
This thread is helpful: XF and XFR ( X250 ) - Page 2 - Jaguar Forums - Jaguar Enthusiasts Forum
The pads I used in mine are listed in this post: https://www.jaguarforums.com/forum/x...e2/#post785912
Unfortunately I'm not happy with the rears. The pad isn't scraping the entire rotor surface on both rear rotors. I removed and inspected the pad on one side and I couldn't figure out why. The pad must be tipped slightly. I may pull them again to check the shim plate for something that could tip the pad sightly (rivent, bump, etc). After a week the pads burned through some of the material and are finally starting to scrap the entire rotor.
The fronts are perfect. The dust all around is near zero which is a huge improvement over the stock pads. The stock pads did grab better in my opinion but I'm happy with the trade off.
KarimPA
Sep 12, 2015 08:15 AM
