Brake pads Low
Old Sep 14, 2015 | 09:25 AM
  #41
lotusespritse's Avatar
Originally Posted by Cambo
If you guys want to run aftermarket pads that don't have sensors, or even if you don't want to pay for replacement sensors, it is possible to turn off the pad wear sensing system, although a dealer won't do it for you.
It's easier to just join the wires together to keep the circuit closed and the light off. A dealer is going to charge $150 to turn it off (2 min job for them). And if you change your mind later, it's another $150. If you strip the wires and join them, you can always buy a replacement sensor if you want to re-enable the feature.
Old Sep 14, 2015 | 09:26 AM
  #42
Originally Posted by sparkenzap
Well, I always change mine myself, too, but it still takes time. And the parts cost $350. if you change the rear rotors, like Jag recommends.
Car guys buy superior aftermarket pads that don't dust and don't eat the rotors before the originals rotors wear out. Then it's only $60/axle for pads.
Old Sep 14, 2015 | 02:24 PM
  #43
sparkenzap's Avatar
Mikey:
Well, I saw that they said one use for the rear rotors somewhere, but I do not remember where the reference was (maybe on here?). However, I am sure the manual says 24mm minimum thickness for the rear rotor, and mine were less than 25 mm when the OEM pads were worn to 4mm thickness.
I plan to "jump" the sensor because I intend to use all of my pads and all of my rotors and i don't want some stupid warning bothering me before my pads are worn out.
Old Sep 14, 2015 | 02:44 PM
  #44
Mikey's Avatar
Mikey:
There were some misguided concepts mentioned here along those lines. The sole criteria is the min. thickness for the rotor.
Old Apr 21, 2017 | 09:17 AM
  #45
Jetset767it's Avatar
Originally Posted by jagular
It should go out on its own. The sensor is usually just a wire which wears through when the pad reaches a certain wear level usually under 2mm remaining. I am not sure which type Jaguar uses but it will either ground a circuit when active or open one, either way the light will go out when the pad wear indicator is connected.
I have 2013 xj
i think it opens curcuit as I wanted to know which pads to order both front and rear looked ok from visual check, so I unplugged the rear sensor still had message then the front sensor still had message.
i believe if you change pads before you get any warning message you don't need to change sensor but once you have the message the sensor needs changing. I paid £8 for Mintex sensor on eBay so I'm going to change everything
H20boy
Dec 24, 2024 03:23 PM
Jefro
Sep 15, 2015 01:44 PM
SeanU
Sep 13, 2015 02:45 PM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
