Can anyone identify what goes to this connection on the engine intake manifold.
Old Apr 15, 2025 | 08:54 AM
Carter334's Avatar
Default Can anyone identify what goes to this connection on the engine intake manifold.
Hi, I completed a smoke test and noticed that smoke was coming from this opening in the engine intake manifold. Can someone please help me identify what connects to this point on the manifold. I cannot find any info online about this particular connection point.
I have attached video as well to show how the smoke is coming from the manifold.
All help is appreciated.
Thanks,
The connection is to the right of the manifold.
This is the connection point that i need help identify what connects to it.
File Type: mov
Old Apr 15, 2025 | 09:36 AM
clubairth1's Avatar
Community Influencer
No car info so pretty hard to say??
Old Apr 15, 2025 | 09:42 AM
Carter334's Avatar
Default 2013 Jaguar XF 2.0
Sorry about that lol.
The car is a 2013 Jaguar XF 2.0.
Old Apr 15, 2025 | 09:55 AM
clubairth1's Avatar
OK thanks. We are mainly a US forum and the US never got any Diesels so we are very weak on any knowledge about them.
I recommend using our friends over on the UK forum where Diesels are in the majority.
UK Jaguar Forum
Or is that a 4 cylinder gas engine?
Old Apr 15, 2025 | 09:56 AM
Carter334's Avatar
Hi, I am in the US as well (Atlanta, GA) and the car is gasoline. I have not been able to find any info on this issue.
Old Apr 15, 2025 | 10:04 AM
Carter334's Avatar
UK Jaguar Forum
Yes it is 4 cylinder gasoline
Old Apr 15, 2025 | 10:18 AM
Carter334's Avatar
Yes, it is a 4 cylinder gasoline 2.0
Old Apr 15, 2025 | 11:48 AM
Vasara's Avatar
Hi,
Your engine is (if i have understand righjt) same as used in Ford Mondeo / Fusion.
Even that is most reliable engine available on Jags its quite rare in JLR line. You might want to past the question on Ford Mondeo / Fusion forum and get much more replys.
Old Apr 15, 2025 | 12:01 PM
Carter334's Avatar
Originally Posted by Vasara
Hi,
Thanks for the input. I will definitely post on ford fusion thread.
Thanks,
Old Apr 15, 2025 | 07:37 PM
gt40's Avatar
There should be a 90 degree rubber elbow attached to a metal or hard plastic pipe that runs over the top of the engine and then clips onto the rear of the cam cover and finally runs down the back of the engine to the turbo wastegate valve as seen in the attached photos.
Old Apr 15, 2025 | 11:32 PM
Carter334's Avatar
Hey I actually played around with it all evening and realized that the clip is broken and looks like an open valve. I have replaced the clip and reset the codes, and everything seems good to go. Hopefully this will resolve the problem for good.
Thanks for the help as well.
Attached Thumbnails Can anyone identify what goes to this connection on the engine intake manifold.-img_6226.jpeg
File Type: mov
04Xjrsteve
Apr 3, 2024 05:58 PM
The_Portuguese
Feb 6, 2021 07:28 PM
felinecat
Mark V - X 420G
Jul 14, 2017 11:35 PM
harvey_birdman
Jun 30, 2013 12:56 AM
rianbechtold
Nov 28, 2008 08:51 AM
