Catylic converter
Old Feb 20, 2018 | 10:08 AM
Dj5ivestar's Avatar
Default Catylic converter
Need new catylic converter should I replace other parts such as sensors gaskets an valves
Old Feb 20, 2018 | 10:20 AM
clubairth1's Avatar
Community Influencer
Not much to go on??
Can you fill in a few more details?
Old Feb 20, 2018 | 02:11 PM
Kaeghl's Avatar
if there was some damage to the engine that cause the converter to fail (headgasket leaking coolant into is one) then I would fix those issues as well.
If the converter simply failed due to age then simply replacing it should be enough.
Old Feb 20, 2018 | 03:10 PM
Dj5ivestar's Avatar
Engine fault Poped up on the screen then the car shut off I pulled over an started the car up again afterwards but I’m not sure if the engine head is damaged
texmanmoore
General Tech Help
Jan 21, 2008 11:00 AM
gvkenny
Jan 17, 2008 02:32 PM
ttreed_81
Dec 7, 2007 02:26 PM
ttreed_81
Dec 4, 2007 02:02 PM
Czubinski
Nov 12, 2007 10:11 PM
