Check Engine light on
Old Oct 16, 2012 | 10:18 AM
Njxfsc's Avatar
Default Check Engine light on
The check engine light had come on my '09 XF Supercharged, couple of days ago. After that, i felt that the engine has not been responding to me while accelerating, even in dynamic mode. i took the car to the dealer and code showed up as P0128 and they replaced the thermostat and thermostat seal, along with with antifreeze. However after picking up the car and driving for 30 miles, that light came back on. Last night when i started the car after dinner, a thick cloud of white smoke came out and then it was fine. Same thing this morning. I am not sure if it is some sort of leak and the engine is burning more fuel??
Any experts could chime in, it would be of great help. I am taking it back to the dealer today...
Old Oct 16, 2012 | 02:13 PM
jagular's Avatar
There is a common problem with 2009 SC engines developing an air leak under the supercharger. They were all supposed to be fixed under warranty as this is an expensive repair of a simple failed part. Others with '09 SC cars should be able to post details.
Old Oct 16, 2012 | 04:18 PM
Executive's Avatar
When a have a CEL, you are supposed to be more considerate to the car. Beating on the car you will cause more damage.
Good luck and hopefully it's covered under warranty. Keep us posted!
Old Oct 16, 2012 | 06:12 PM
Njxfsc's Avatar
@jagular Thanks for your insight. The reason I am not sure is because it did not spit out any code that indicated lean condition
@executive I did not beat up on the car. I usually drive with dynamic mode but i felt a lag in that mode too... will keep you guys posted
Old Oct 16, 2012 | 07:56 PM
jagular's Avatar
I am not sure the fault leads to a lean condition even though it involves an air leak. The leak may push measured and supercharged air out rather than drawing unmeasured air in. The former will cause the ECU to put excessive fuel in as it measures air taken in, calculates correct fuel amount but not all the air gets to the cylinders to be mixed with fuel, you then get excessive enrichment in the cylinders from correct fuel amounts. Boosted engines can produce odd results when air leaks out. Naturally aspirated engines always leak extra air in so produce lean effects.
BTW white smoke could be coolant burning. Isn't the SC intercooler water cooled?
Old Oct 18, 2012 | 05:03 PM
Njxfsc's Avatar
Got the car back - it is fine now. The breather hose had loose connection and it was resecured. They also replaced the air filters due to airflow imbalance.
Old Oct 19, 2012 | 08:47 AM
jagular's Avatar
There you go, boosted air was being blown out, making the mixture too rich.
Not sure how the air filters would be involved. Mine has only one, does the SC have two?
Old Oct 19, 2012 | 11:25 AM
armira9's Avatar
Banned
Check engine light on a 2002 toyota highlander 4 cy?
I changed my air filter a few days ago. I noticed my check engine light come on today. Could i have done something wrong putting a new air filter in ? thanks
Old Oct 19, 2012 | 02:09 PM
jagular's Avatar
Air leaks downstream of the AMM will throw a CEL. Cheap code reader OBD II will get you the codes. That helps track down the issue.
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
