Check Engine light oh $hit!
Hey folks, early this cold morning the check engine light lit and stayed lit. Nothing wrong with the engine what so ever. When I turn the engine I see a red display on the speed screen for a breif second looks like something about the battery. Upon start up I turned on the front heated seats and the lights. THis could have triggered a low bat alarm. I will test the battery and charge it and then reconnect. In the event I have to check codes, I have a OBD reader. Where do you connect the plug?
Thanks, Riq
Thanks, Riq
Most CEL (MIL) mean nothing. If intermittent the light goes out after a specified number of ignition cycles. If a fault then it will be electrical as 95% of CEL are triggered by electrical component failure.
BrentGardner
29
Dec 16, 2024 12:13 AM
