Cooled seat back DIY -Failed fan or filter replacement
Old Jul 25, 2018 | 09:52 PM
Bigg Will's Avatar
Great write up, Thanks!
Old Aug 15, 2018 | 06:12 AM
Rok Korber's Avatar
How did you get to the filters?
Where exactly are they and what do you need to do to get to them?
Thanks,
Rok
Old Aug 16, 2018 | 12:41 AM
John Williams's Avatar
The backrest filters can be seen in the pictures (white disc) The cushion filters are under the front of the seat, half turn removes them, again look for the white disc.
Old Aug 19, 2018 | 10:27 AM
luvinmyjagxf's Avatar
Excellent write up. I too have issues with the airflow in the driver’s seat. It never occurred to me that there were filters which may be clogged or a broken duct. Thanks.
Old Oct 22, 2018 | 11:23 AM
clubairth1's Avatar
Community Influencer
What's interesting is on the 2018 Fords they replaced the seat filters with flat pieces of plastic with holes in them. No filter at all?
Maybe just something to keep the big stuff out of the fan?
Old Oct 22, 2018 | 12:22 PM
vector4's Avatar
I'll be honest, I did this procedure on my 2013 because I wanted it to flow more air (I live in Louisiana, it's HOT, I need as much venting as I can get!). My thought are this:
My filter was perfectly clean without a spec of dirt so I just removed it to try to get more flow. Not only does the filter exist but the fan is mounted behind a metal crossbar AND there is plastic ducting to get air to it's intake. IE, I can't figure out how anything significant could possibly get in there. My ducting wasn't cracked at all, maybe they updated the ducting in the facelift. I really like how the system uses a peltier effect panel, neat setup, and refreshing to see that it actually cools the air some before venting it to you.
Old Oct 23, 2018 | 06:29 PM
clubairth1's Avatar
Did you notice any difference in air flow after removing the filters?
Old Oct 25, 2018 | 10:13 AM
  #28
vector4's Avatar
Might be a placebo effect but I'd say yes. However, even if it is more, its only slightly more. Nothing significant, I'd love it to really blast air out.
Old Apr 20, 2019 | 09:40 AM
Mattman7474's Avatar
Apologies for bumping such an old post but...is there supposed to be an ‘open’ top? Or am I missing a lid?
It looks as though the air is just being blown towards the headrest instead of into the seat
Old Apr 23, 2019 | 09:14 AM
  #30
vector4's Avatar
That's odd, there is for sure a cap to the blower that forces it into an air bladder in the seat. I wonder what happened to yours.
Old Apr 23, 2019 | 05:17 PM
  #31
So the top of this should be blocked off? That’s how I removed it from the seat (ignoring the terrible silicone job!)
strange!
Old Apr 23, 2019 | 05:52 PM
  #32
vector4's Avatar
strange!
No that top is the excess. On the other side you aren't showing there is another outlet that blows into a chamber that goes to the seat back.
It's a peltier plate. Current one way produces heat on one side and cool on the other, when you want heat the cool side exhausts into the seat. And vice versa when you run it in cool mode.
Old Jul 25, 2019 | 01:31 PM
  #33
harryf's Avatar
Default Fixed the one behind the driver's side the passenger one was fine.
I put duct tape (the stuff you put on AC ducts) it worked easily. I didn't have to remove any of the zip ties. Just unscrewed them as in above directions, pulled it out and examined them. Put the duct tape on and then reinserted. Back is nice and cool. Need to check the ducts underneath the seat though, but they work okay.
Attached Thumbnails Cooled seat back DIY -Failed fan or filter replacement-img_20190721_130541.jpg
Old Apr 25, 2020 | 01:53 PM
  #34
Randy Mounts's Avatar
Just did my filters Thanks for the great info
Old May 23, 2020 | 09:49 AM
  #35
Tufarlian's Avatar
This thread has been very useful but I haven't been able to solve my problem. I'm hoping someone may be able to offer some more advice.
Car is 2009 XF 3.0 D S Portfolio with climate seats. Drivers seat cools but has suddenly stopped heating.
Checked fuse 25 in footwell. That's OK. Followed the advice here and checked both seat back and base fans and flexibles. No cracks in either. Both filters aren't exactly new but fairly clean and look OK to me,
With the base filter removed when I set the seat to heat I can feel the fan start, first slowly and then faster but after about 10 or 15 seconds it stops.
I've looked for broken wires but can't find any.
Any advice much appreciated.
Mark
Old Jun 1, 2020 | 12:14 PM
  #36
For heating I think there is a heat pad in the seat aswell as the peltier unit, so the heat pad may have failed??
Old Jun 1, 2020 | 02:31 PM
  #37
Tufarlian's Avatar
Thanks.
I thought it was just the heated seats that had a pad.
I'm sure I've read somewhere it's peltier unit if heated and cooled, pad if just heated.
I don't know if there is a pad or not.
Old Jan 12, 2021 | 09:44 PM
  #38
POD XF's Avatar
I just repaired the duct in the seat back on my drivers seat, this thread was super helpful, thank you. An extra bit of information that might be worth knowing is that the duct and blower systems are not left- or right-handed, it is identical in both seats; I took the back off the passenger seat to check it after repairing the drivers seat. The passenger side was in perfect condition. The parts could be robbed from there if someone had a badly damaged drivers seat duct and didn't care about the passenger seat.
Old Nov 25, 2025 | 09:44 AM
  #39
jwburch21's Avatar
Smile Thank you!
This is great! Thank you for doing all the photo documentation!
stevepaa
Nov 4, 2018 07:50 PM
RaceDiagnostics
Oct 28, 2018 12:08 PM
RaceDiagnostics
Jul 30, 2016 04:55 PM
Grio
Jun 20, 2016 10:33 PM
Cambo
Dec 10, 2011 10:21 AM
