Dead Battery
Old Dec 31, 2015 | 08:48 PM
Lawrence Thompson's Avatar
Default Dead Battery
Hello out there. I have a 2010 Jaguar XF. My battery died and my trunk lock switch is broken. I can't get into my trunk charge it change my battery. Can anyone help me?
Old Jan 1, 2016 | 12:34 AM
Welcome to the forum Lawrence,
I've moved your question from Jaguar Forums Feedback & Suggestion Center to X250 forum. Members here with the same model will be able to help.
Old Jan 1, 2016 | 10:17 AM
n8ertot's Avatar
Next to the button on the trunk you use to open it is a hole plug that you can pull out (on the left of the trunk opening button, I think). Once that's out, you'll see a keyhole that you can use to open it.
Old Jan 1, 2016 | 10:57 AM
DPK's Avatar
DPK
Just to add..The key is in your Smart-key fob
Old Jan 1, 2016 | 11:04 AM
Thank you for your quick response. I've tired the smart key as above. Inserting the in the keyhole. It just turns back and forth with opening the trunk. Are there any other ideas that I can get power to open the trunk?
Old Jan 1, 2016 | 11:08 AM
DPK's Avatar
DPK
Can you pull back on the rear seat back?..I think there is a release lanyard back there
\You may have to turn the key a little harder...It is not electrical in function..it should open it..Try Pushing down On the trunk lid while you turn it.
Old Jan 1, 2016 | 11:16 AM
I have also tired that!!! This is so frustrating!!
Old Jan 1, 2016 | 12:08 PM
jimbov8's Avatar
If you can open the hood, hook up a power source to a ground point and a suitable positive and open the trunk that way.
That is the only way I can think of in your situation.
Old Jan 1, 2016 | 06:11 PM
n8ertot's Avatar
There are also jumpers that can plug into the cig lighter.
I just opened mine with the key, and like DPK said, I had to push down on the trunk and really crank it to get it to release.
Old Jan 1, 2016 | 06:12 PM
DPK's Avatar
DPK
That's a good idea...I invested in one of these to save on the hassle of looking for something to hook on to under the hood.
Universal Car Computer Memory Saver Automotive Engine Maintenance Data Storage | eBay
Old Jan 1, 2016 | 07:24 PM
sparkenzap's Avatar
So you guys think your cigarette lighter is connected to the 12 volt bus when the car is powered down? I suggest you try that out before you depend on it!
Old Jan 1, 2016 | 08:41 PM
DPK's Avatar
DPK
By just opening the door and plugging in, this shows that the Cigarette lighter socket is connected and powered up to the Car's 12v system...Car had been sitting for 12 hours prior to opening the door.
Zap...rather than throwing wet towels, check it out first before you speak again.
Old Jan 2, 2016 | 11:36 PM
sparkenzap's Avatar
You should THINK before you post! Exactly what do you think pulls in the relay to connect the cigar lighter to the battery if the battery is dead??????
Pull your battery leads, lock all your keys in the trunk, then show me your picture!!!
Old Jan 4, 2016 | 12:52 PM
tbird6's Avatar
Hopefully Jaguar did not change the XF from the S Type. You should have an emergency jump point in the front fender well on the passenger side of the car. Remove the wheel well liner to take a look. I have not had an XF to check this on yet.
Here is a picture from an Lincoln LS which is built on the same DEW98 platform.
https://www.jaguarforums.com/forum/a...1&d=1451933448
Tahoe Dave
Jan 4, 2016 09:26 AM
dhog4n
Dec 31, 2015 09:31 PM
Vector
Dec 30, 2015 06:59 PM
Johnken
Dec 29, 2015 02:16 AM
jacob11379
Dec 26, 2015 01:57 PM
