Doing your own oil changes on 5 Liter engines
Old Mar 2, 2012 | 08:43 PM
  #41
plums's Avatar
Originally Posted by cwood
lets continue the fun by debating doing the oil change yourself vs taking it to the dealer for the other "stuff" they include...that in my case takes it up to $690. This includes the seat filters! Now some of the guys at work suggest that I of all people should have the seat filters replaced ASAP....but I think I can probably do without this, check the pollen filter and call it a day.
What am I missing? (I have all the equipment etc and have built cars ground up in my garage so I have the skills. Just concerned about the higher end vehicle and its sensitivities)
Well, the "seat filters" are important because they mask the smell when the "evacuation orifice" is involuntarily opened after parking at Taco Bell.
Just had dinner
Old Mar 3, 2012 | 07:41 AM
  #42
Executive's Avatar
The front seats have fans mounted underneath that are activated once you turn on heated/cooled seats. The filters are attached to the little fans to keep them clean and possibly letting anthing damage the fans themselves.
The seat filters you guys can check yourselfs. It's very easy to do and i think they only cost few dollars, if they need to be replaced.
Old Mar 3, 2012 | 09:11 AM
  #43
jagular's Avatar
Is there a risk of overspeeding the fans under certain digestive conditions? Are the bearings robust enough for such conditions?
Old Mar 3, 2012 | 10:59 AM
  #44
Rique's Avatar
Probably all stainless steel and teflon parts to avoid corrosion.
Old Apr 21, 2012 | 02:30 PM
  #45
macc24's Avatar
So was the DIY adventure a success? Where is the oil filter on the XF located? While the design of the engine is clean, there sure are a lot of shrouds.....thanks Jaguar engineers for tacking on 1.0 hours of extra book time for removal of the plastic bits in the bay.
Old Apr 21, 2012 | 05:33 PM
  #46
jaglover922's Avatar
There is a drain plug on the 5 liter. The problem is, is that it doesn't drain out all the old oil. For XF owners, I would suggest you not remove the engine cover all the way. It's a you know what to install once removed. Lift it up in the front and prop a can or screwdriver under it and change the filter. For XJ owners, you can reset the light by purchasing a Service Reset Dongle online. It's $200.00+, but you don't have to go to the dealer to reset you light. Plus you can update it for newer models online
Old Apr 21, 2012 | 09:18 PM
  #47
Rique's Avatar
For those that keep at it with the no drain plug on the 5.0L here is a diagram of the engine. It seems there are two plugs but I'm not sure.
Why is it that oil is not compleatly drained? I have serious doubts about this the plug is down below no reason for it to not drain all the oil.
Comments...
Attached Thumbnails Doing your own oil changes on 5 Liter engines-jaguarengine5.0l.jpg   Doing your own oil changes on 5 Liter engines-jaguarengine5.0l2.jpg
Old Apr 22, 2012 | 07:38 PM
  #48
Here's what I want you to do when you change your oil. Drain the oil into a container that can hold up to a least 8 quarts. Tell me how much you get out. Then I will tell you how much is taken out but a vacuum device that I use on a regular basis, because I'm a Jag Tech. Then we will compare and see what the difference is. I'm not trying to prove you wrong by any means. I would like to know myself. I'm not going to try it for myself, so that's why I want you to try.
Comments...
Old Apr 22, 2012 | 08:27 PM
  #49
Rique's Avatar
Well, I don't want to sound stubborn on a point you could be right about. I will drain the pan first and measure exactly how much I get. I will then hook up a vacuum system and drain the rest if I get less than the expected 8qrtz. Can you or another tech advise how long a vacuum probe you need or do you use a flexible hose. I have a generic system I use on auto transmissions.
Old Jun 7, 2012 | 09:46 PM
  #50
Rique's Avatar
Default update on My Oil Change
Hey Folks, I did my oil change today. I actually cheated a bit, this is what I did.
I got my self a portable vacuum pump and made a vacuum flask out of a glass coffea container. Hooked the tubing to the engine vacuum pipe and sucked away. So far I have gotten 6 liters out before the hose did not pull any more oil out. I would appreciate if any of the Techs here can advice if I need to pull the bottom drain plug to retreive the remaing two liters of oil or if the vacuum pipe goes all the way to the bottom. I will post pics of all the process.
Old Sep 12, 2012 | 02:02 PM
  #51
jahmezis45's Avatar
how do i get rid of the change oil indicator after i change the oil? Thanks
Old Oct 22, 2012 | 11:58 AM
  #52
hlgeorge's Avatar
https://www.jaguarforums.com/forum/x...rmation-20086/
Old Oct 23, 2012 | 09:58 PM
  #53
jahmezis45's Avatar
Thanks for the link but ive tried this method numerous times and it hasnt reset the light at all. I did get a message once or twice saying "not available see owner manual"
kelliott
May 31, 2022 05:26 PM
cissdm
May 3, 2016 06:02 AM
bdboyle
Sep 4, 2015 06:16 AM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
