Driver seat wont move
Old Dec 27, 2018 | 01:10 PM
jahmezis45's Avatar
Default Driver seat wont move
Out of no where my driver seat stopped moving. Moving seat Forward or back doesn't work nor does the tilt forward or back. The only seat function that works is the one that releases or adds pressure to the seat. I changed the module thinking that was the issue. I check the fuses they were all good. Could all of the under seat motors went bad at the same time? Any help appreciated.
Old Apr 24, 2019 | 12:44 PM
karpe's Avatar
Did you solve your problem? I have the exact same issue.
Old Apr 24, 2019 | 03:27 PM
lotusespritse's Avatar
An old thread, but this guy needed to get out the voltmeter to check out what is getting power and what isn't. It isn't likely to have multiple motor failures at the same time, and a voltmeter would answer if they are bad motors or if they are not getting any juice.
I also really wonder what people mean when they say they checked the fuses? Did they really put a meter on them, or just look at them? Sometimes fuses go without looking bad.
Old May 31, 2019 | 01:45 PM
karpe's Avatar
I got this sorted. Had to take it to the shop, as I could not remove the seat. The switch pack was bad, luckily I found a replacement unit from eBay.
jcwellsq8
Aug 17, 2018 02:21 PM
RC Tod
Jun 27, 2018 08:55 AM
EJ Garity
Aug 17, 2015 12:09 AM
Toshnali
Apr 28, 2014 05:59 PM
TonyCanoe
Jul 21, 2013 09:13 PM
