Expansion Tank
Old Aug 7, 2017 | 07:18 AM
Bufford85's Avatar
Default Expansion Tank
good morning .... I have a 2013 X250 I'm getting a 'low coolant level' warning but the coolant level isn't low. Car isn't overheating tho so that's good. Dealership is saying I need a new expansion tank. $405 usd has anyone else experiences this?
Old Aug 7, 2017 | 09:33 AM
Blackcoog's Avatar
It is common on the 2009 for the float in the tank to stop working but there hasn't been many complaining about other years. Check to see if the float in the expansion tank is working.
Old Aug 15, 2017 | 03:35 PM
Gpalace's Avatar
225.00 at NY Jag....replace it yourself...pretty simple....New tank comes with the sensor and float...their price sounds high ....
Old Aug 16, 2017 | 12:17 AM
Bigg Will's Avatar
I'd shop that item sir, got mine for $80, it's about a 20 min job to install.
Old Aug 17, 2017 | 11:21 AM
kenc's Avatar
Dealers are aa rip off. Mine charges 50% over msrp for parts.
Old Aug 17, 2017 | 06:42 PM
timfountain's Avatar
I purchased an original Jaguar OEM expansion tank brand new on ebay for $112. Apparently the SC one is different to the non-SC one, but the one I got said it was for an S-type R, but fitted like a glove and had the same part number as the XFSC one. Installation was trivial, just have one of those tube squeezing tools to stop any coolant leakage from the block. It took all of 20 minutes. It is an easy DIY. $405 is just nuts. FYI The local Jaguar dealer quoted me $230 all in to do the job.
Old Aug 18, 2017 | 10:03 AM
Blackcoog's Avatar
I have gone through 3 tanks now. The 4.2L SC (XF and S-type R) have a different coolant tank vs. all the other XF engines and it's about double the cost.
The top nipple breaks due to the engine rocking when revved. I added extra hose and looped it around so the engine no longer pulls on the top nipple.
Old Aug 18, 2017 | 02:08 PM
Interesting. I had that happen two times on my older S-types, but with the XF the issues I and most posted seem to report is the sinking float switch, which triggers a false coolant low message.
