(Final product and install) Aeroforce gauges
So finally the final product. Myself and Redjaguar100 have been working on this for over a year. The hardest part is locating a vent. Jaguar will not sell the vent by itself, it is part of the dash in there system. So I have been searching wrecked XFs for quite sometime and finally found a salvage yard on ebay and he went out there and pulled the vent for $20.
You can use your vent but if you ever want to sell your Jag it would have to be part of the sale. The gauges read 30 perimeters, I have them setup so it shows two on each gauge. You can show 8 but it's very small, or you can have them go through a duty cycle and it will go through what you program. I have mine reading Boost/Vac, A/F Ratio, Intake, and Coolant.
That's pretty cool!
Can you change the colour of the backlighting or is it fixed in blue?
Assuming it runs via OBD2, can work with other models? (obviously the hardware/mounting will be different)
It's fixed blue, but they have different colors. Yes it's OBD2 and works with any vehicle, they do make specific for some makes that would show more perimeters than the generic like I have. Not much more, but some pretty cool features.
Redjaguar100 and CHFXS did a great job on this !
I have ordered my gauges from Aeroforce today from Todd Austin at sales@aeroforcetech.com....
Mention the forum and Todd will set you up..cost was 363.00 which included two extra faces and shipping.
The pod vent will be ordered from Block8head contact is Ben Ho at
sweetlove618@gmail.com
Again mention the forum and the project and Ben will set you up...Single pod is 85.00 and double is 130.00..you will need to remove your vent and send to Ben unles you locate a replacement vent.
aholbro1
Dec 29, 2024 06:46 PM
trosty
26
Dec 18, 2022 06:40 PM
