Hard reset for electronics on XF
Old Feb 8, 2019 | 01:55 PM
Newcastle1's Avatar
Default Hard reset for electronics on XF
Hi Does anybody know if there is a procedure to do a hard reset for the electronics on a XF 2.2 d 2014 model.
I'm having intermittent problem with Climate control not working.
Old Feb 8, 2019 | 02:02 PM
JagV8's Avatar
To reset the module concerned you need an OE-type tool. It's not likely to help but if you've the money...
Old Feb 10, 2019 | 03:25 AM
Newcastle1's Avatar
Thanks for your reply but what is an OE-type tool?
Is it some type of diagnostic module?
Old Feb 10, 2019 | 10:00 AM
les's Avatar
les
He's probably referring to Jaguar SDD diagnostic equipment.
Try a battery disconnect first by removing the earth cable for a few minutes. You will have to reset the auto window setting afterwards though and maybe the seat memory.
Just a thought, have you had the A/C refrigerant checked?
Old Feb 10, 2019 | 05:15 PM
Newcastle1's Avatar
Thanks for your reply. I assume the radio also requires resetting also. I haven't had the a/c checked but I would have thought that if it was empty it just wouldn't regulate the temp.
My intermittent problem is blower does not work and the air vents don't open.
weisberg
Oct 20, 2014 07:20 PM
Fairlane500
Dec 18, 2009 11:23 AM
atilamejias
Feb 4, 2009 11:43 AM
badmojo
Jun 26, 2008 12:16 PM
badmojo
May 4, 2007 05:51 PM
