Headlight Questions
Old Mar 22, 2026 | 10:24 AM
bdboyle's Avatar
Default Headlight Questions
'12 Portfolio to restate. HID headlights.
Assuming that age had started to creep in...checked the aiming, it's on. But, as compared to my Jetta (also HID headlights), it seems a bit dimmer than it should be. Auto main/dip works fine, just the amount of light (I know, a personal observation, haven't put a light meter on it, or measured it, just observation of admittedly aged eyeballs...) seems a bit down.
So...question(s)...do these bulbs age (ie like the halogens/sealed beams) and decrease in intensity as they age or is it a binary state (either full brilliance or suddenly dark)? I see replacement is somewhat involved (loosen up the front bumper trim, etc); if I'm going in there because age has taken some of the spunk out of the bulbs, should I stay with the OEM bulbs or update to LED replacements?
Interested in the collective's thoughts from those with insight or have gone down this road. (and, no, a set of Super Oscars on the front aren't the answer...LOL)
TIA.
Old Mar 23, 2026 | 05:24 PM
webb 72's Avatar
With the HID bulbs the electrodes ware out through constant arcing when on, the brightness can can be reduced more than 50% if they are original
halogen lights normally just blow
hope that helps
Old Mar 23, 2026 | 05:50 PM
bdboyle's Avatar
hope that helps
That's what I was wondering, just wanted to confirm. IIRC, the HIDs in my brand new '17 XE were spectacular, as were the ones in my former '13 XF (which I bought as a 2-year lease turn-in), but I'm finding that the (14 year old) main beams light up with the proper pattern but just aren't blazing bright (which, when driving down dark B roads, can be a bit disconcerting especially when they sense oncoming lights and auto dip.).
I believe they're type D3S. Will spring for a pair. Sheesh, by the time I finish refreshing POs neglect, I'm going to have one sorted ride. Rear brakes and track arms this week...
Old Mar 24, 2026 | 04:15 AM
John Williams's Avatar
I can recommend these bulbs!
Old Mar 25, 2026 | 07:12 PM
bdboyle's Avatar
John: are the plug and play? Don't throw CAN bus errors?
Looked online...and they seem to be getting the mindshare going forward.
TIA..
PeteK812
Sep 27, 2025 04:02 AM
NorXKR
Oct 21, 2022 07:10 AM
Gerald Clark
Oct 10, 2022 01:23 AM
catlover
XJ40 ( XJ81 )
May 12, 2012 03:27 AM
Reverend Sam
Nov 30, 2011 11:49 AM
