HID Kit for Jaguar XF
Old Jun 18, 2008 | 06:51 PM
ibjags's Avatar
Default RE: HID Kit for Jaguar XF
HID Kit ($200)
can you send some info on this HID kit?
where it was purchased what does the kit consist of?
im curious about it
Old Jun 18, 2008 | 07:55 PM
jag_genius's Avatar
easy to install.. headlamps come out in 2 minutes.. probably would get no warranty..on the headlamps tho..
Old Jun 20, 2008 | 07:35 PM
jag_genius's Avatar
maybe the crappy ones.. but the best ones tee in .. plug directly into the light connector.. and use the power and ground giving by the cars connector
Old Jun 25, 2008 | 04:22 AM
veffremov's Avatar
I did similar mod on my Acura MDX some time ago. A few things to consider:if your XF with hallogens does not have projector lenses, the HIDs will look awkward and most likely blind all other drivers. The cure is to replace the whole headlight assebly with one with projector lenses, but on Jags that is quite costly.
I got my HID kit from eBay for $79, most of these require you to use a knife to "adjust" the bulb fixture to fit the headlight, not a big deal, but defenitely notplug-and-play. On my kit the bulb was supposed to be H7 and it looks quite like it, but the plastic was too wite so I needed to cut it a bit.
If you have trouble with the power connector you can cut thesocket and stick the cables directly in the female plug that powers the hallogen light bulb - make sure you get the correct polarity on the HID voltage converter, otherwise you could be in a bit ofearly 4th of Julyshow.
Also most of the people who sell these kits are quite helpful and could send you additional powersockets for little or no extra cost.
Old Jun 26, 2008 | 05:41 PM
aquill1's Avatar
Try taking some pictures so we can see what you have going on. I hope it is a nice kit for $200 bucks though.
Old Jul 15, 2008 | 06:45 PM
aquill1's Avatar
That's probably the smart thing to do considering the car is new and warranty would clearly be voided when mods are made.
Old Oct 2, 2008 | 02:42 PM
whiteSTR's Avatar
Be careful with the heat coming off the HIDs.. HID bulbs put out A LOT of heat and Ive seen many people ruin their headlights with them.. The housing in the standard on may be different than the ones in the premium model and you could melt parts of your headlights.. Its unlikely, but I have a feeling the headlight housings for the XF arent cheap..
Old May 10, 2011 | 01:58 AM
hawee's Avatar
It was mentioned that you can purchase the whole headlight assembly to have hid lights, is that really possible?
I've been looking around and can't seem to find anyone selling the hid headlight where i could just remove my current ones and replace them with it.
I just purchased my XF this past weekend and a bit shocked that HID aren't included.
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
jdzubas
Oct 4, 2015 09:14 AM
Sprayall
Sep 3, 2015 07:49 PM
Harry Dredge
Sep 2, 2015 02:26 PM
