How to tune my xf 3.0 sc the same as the f type s
Old Dec 21, 2012 | 09:49 AM
hcyhcy05's Avatar
Default How to tune my xf 3.0 sc the same as the f type s
I would like to know . What is the different btw these 2 engines . I would like to tune my engine.from 340hp to 380hp pls advice thx.
Old Dec 27, 2012 | 03:12 AM
quanva's Avatar
based on the XF's their would be no internal difference..with a difference that small would be ECU tuning.. a simple Remap should fix that
Old Dec 27, 2012 | 09:57 AM
carzaddict's Avatar
ECU, maybe different exhaust, maybe different intake.
no one knows for sure what parts are different internally. but the chances are high that its 1 (or all) of the 3 I just listed
Old Dec 27, 2012 | 10:26 AM
jagular's Avatar
Supercharged engines don't need efficient intakes or exhausts. Naturally aspirated engines do benefit from these areas. Almost all modern engines are already optimized for intake and exhaust.
To make a supercharged engine more powerful is child's play. You increase boost at the top end of the rpm range. For more power you can usually change the blow off valve software, modern mechanical supercharging systems borrow architecture fom turbocharged setups. They are tuned to overboost with a software controlled blow off valve which usually bypasses boost pressure back to the intake side.
To increase torque you need to fit an overspeed drive pulley so as to increase combustion chamber pressures across the rpm range.
The limits are detonation, desired fuel economy and reliability.
For road cars the limits are generally the numbers desired for the brochure to justify a price premium for S or RS models!
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
ZJag
26
Sep 5, 2016 03:33 PM
KarimPA
Sep 3, 2015 07:32 PM
dcvickers
Sep 2, 2015 06:14 PM
