Identify part for me
I could be wrong but it looks like this is leaking coolant. It's right of the waterpump. I saw someone else post this particular part and a comment about the plastic connector being the culprit, but I have not been able to find that post again. This is the only leak I've found but I haven't had a chance to look at the rear crossover yet.
Good point and has your water pump and plastic cooling hoses been changed yet?
Since it's a small leak now I would gather the parts you need as there is a number of them. The rear water manifold is another leaker and it requires the SC to come off.
This leads to the next question? How is the SC snout? Making any noises?
It helps to tell us what car you have? Full info.
Maybe where your at too as this is mostly US people so we are not familiar with some of the options not sold in the US.
Glad to see you caught it early too!
Yeah I have replacement parts except for a couple still coming. I have not been able to spot a leak on the rear manifold yet so I'm not sure I need to do it yet. My upper pipe is the newer version already so not worried about that, though I will upgrade it if I need to replace the rear. I'm hoping to avoid pulling the SC.
I think you have seen this but if replacing those plastic cooling pipes we now have an aftermarket supplier that has released Aluminum versions!
Several guys have installed them and no problems reported.
Al. Cooling Pipes
There is also a possibility they will release the rear water manifold in Al. as well. This would be a massive step up in the reliability of the cooling system which is our number 1 problem area!
Al. Cooling Pipes
Juha Lystila
Jan 25, 2023 07:05 AM
