install additional sub woofer?
Old Feb 7, 2014 | 02:49 PM
BigD660's Avatar
Default install additional sub woofer?
i have a 12" kicker L7, dx500 amp and full wiring from my truck but i dont know anything about my jags wiring harness. can i do it myself or should i have someone else do it?
Old Feb 7, 2014 | 04:26 PM
2010 Kyanite XFR's Avatar
It's super easy if you have the factory subwoofer, as the battery and the speaker level inputs are all in the back. If not, it will be a bit harder to find the signal you will need.
Old Feb 8, 2014 | 09:41 AM
BigD660's Avatar
What is jailbreak tuning? i must have it done lol
Old Feb 8, 2014 | 11:08 AM
They reprogram the car's ECU to make more power.
Old Feb 8, 2014 | 12:23 PM
JagVonder's Avatar
What is best speaker to tap into? I have sub and amp is like to install. Do I tap into door speaker or sub or??
Thanks!
Old Feb 9, 2014 | 12:23 AM
Gn4hir's Avatar
If you have the factory sub, that is where you need to tap as the system has already crossed over the signal response sending sub frequencies to the sub and everything above the sub to the full range speakers.
If you don't have a factory sub, you can pull signal off the woofer speakers, both left and right as the bass frequencies are still in stereo until combined by your sub amp into a mono signal.
The low level signal coming from the headunit is not available to you as it is digital prior to the amp but you can pull the high level output from the wiring from the amp headed to the speakers rather than trying to get to a door speaker.
Here is the wiring going to the Sub
If you need the wiring coming off the amp going to the speakers, PM me and I will send you the pdf file.
https://www.jaguarforums.com/forum/a...ine=1384136263
Old Feb 9, 2014 | 01:38 AM
JagVonder's Avatar
Sweet! Thanks for the info.
Old Feb 9, 2014 | 01:43 AM
JagVonder's Avatar
One other question. I do in fact have the sub. But where would or should I run the new amps remote wire to??
Old Feb 9, 2014 | 12:03 PM
Does your amp have speaker level inputs or signal sensing capabilities? If not you should get an Audio Control LC2 which will take the speaker level inputs and convert them to high quality line level signal and also has signal sensing so you won't need to find a remote turn on.
Old Feb 9, 2014 | 05:30 PM
Ajay Mann's Avatar
How would you guys get the remote signal to the aftermarket amp? so it does not stay on 24/7. Doing the hi/low output converter if I am wrong correct me but iI think you would not have sub control from the head unit.
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
Majik Lasers
Aug 2, 2024 01:49 AM
Dagny
Jun 11, 2024 01:06 PM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
