? on intake airflow path and routing on S/C engines
Old Feb 20, 2014 | 12:33 AM
Ish's Avatar
Ish
Default ? on intake airflow path and routing on S/C engines
I've been poking under the hood and under neath the car to check on some coolant hoses that are leaking (solid orange stalagmites, man...), and then I began to look at the intake ducting, trying to figure out the intake air path from the exterior to the cylinders.
Co-worker has a current model M5, which has an interesting airflow pattern (reversed to what we normally expect), and in tech school, we had to trace "a molecule of air" through the aircrafts pressurization system, so I'm really curious on how Jaguar did this.
Is there a diagram out there that shows the airflow through the engine? I'm really curious where the airflow path is in relation to the inter-coolers.
And its probably time to clean the K&Ns... Dusty as hell in this part of the world...
TIA
Ish
Old Feb 20, 2014 | 02:06 AM
JagV8's Avatar
You can probably get workshop manual / tech guides from ebay. They're on jag's TOPIX but there's a cost.
Or try online parts places, as they tend to have exploded diagrams.
dsnyder586
Dec 29, 2024 07:39 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
FeralJag
US Lower Atlantic
Dec 3, 2018 01:05 PM
cissdm
May 3, 2016 06:02 AM
rachelstr
Sep 3, 2015 12:59 PM
