Jacking points Jaguar xf 2.2d
Help please….. I cannot make sense of where the jacking points are on my 2013 2.2d xf.
I have seen the diagram from the workshop manual but the front ones are so far inboard I don’t think my jack will reach. Or do I need to remove the plastic covers underneath first? Can’t see tyre shops doing that!
What jack are you using? If it's a trolley jack or similar just roll it under and it should reach fine. Don't need to remove anything. But yes - much further inboard than I've ever seen on a car before!
If you're using the scissor jack (which is really only for emergency use - I wouldn't use it unless no other options) then you have to use the point marked on the pinch weld at the edge of the car (see owners manual for details)
lancia delta
Oct 11, 2017 04:37 AM
