Jaguar XF Fog light
Old Nov 13, 2013 | 02:00 PM
Inguss/Marita's Avatar
Default Jaguar XF Fog light
Hi!
I have Jaguar XF 2008. I have problem with rear fog lights, i chek lamps, they are ok but still didnt work.
Do anyone knows where i can find fog light fuse or there is some other problem, please help me!
Old Nov 13, 2013 | 02:48 PM
rbobzilla's Avatar
I don't know where it is located, but just to be certain, you do have your headlights on when trying to turn on the rear foglight, correct?
Old Nov 13, 2013 | 03:02 PM
Swimref's Avatar
And please don't post the same exact thing four times. Once will work just as well and without offending the readers.
Old Nov 13, 2013 | 11:19 PM
Default HI!
Sorry for those four times, i`m jsut useing this site first time!
Yes i`m trying to swich my rear fog light, but nothing happening!;(
Old Nov 13, 2013 | 11:20 PM
Yes my headlights is on!
Old Nov 15, 2013 | 09:28 AM
Fury1995's Avatar
The rear fog light button is beolow the air vent on the driver's side of the vehicle (closest to the driver's window). When the switch is activated, there is an additional light on the dash in the instrument panel that illuminates in amber in addition the regular light that illuminates in green (the green light is on the left and the amber light is one the right). Both of these illuminated lights are at the bottom of the tachometer dial.
Are you seeing both of these lights illuminated?
Old Nov 15, 2013 | 09:42 AM
Default hi
Hi!
I can see only amber color fog sign. Thats it, nothing else!;(
Old Nov 15, 2013 | 09:48 AM
And i have one more problem with DPF Full messege in dash. What i need to do to get off that message!?
And is it a big problem!?
Old Nov 15, 2013 | 09:59 AM
The thing is that amber indicate in dash, but nothing hasppen in lamps, back fog lights is off!;(
Old Nov 30, 2013 | 11:22 AM
Peter.H's Avatar
DPF is "diesel particulate filter". This warning comes on when you have been driving short distances rather than longer ones and the particulate filter is getting full. It is designed to self-clear but can only do it when engine runs hot for a while. The filter clears itself only when the engine is operating at optimum temperature and this requires you to drive for about 20mins at a speed higher than 40mph or so. Go for a highway run for half an hour and it will clear itself. If it doesn't, you need to visit your dealer.
Old Nov 30, 2013 | 01:19 PM
Welcome to the forum Inguss/Marita,
BrentGardner
29
Dec 16, 2024 12:13 AM
gene1
Sep 3, 2015 08:04 PM
tonydbaker
Aug 30, 2015 11:02 PM
gene1
Aug 27, 2015 09:35 PM
gene1
Aug 27, 2015 08:56 PM
