Key Fob Programming
Old Sep 27, 2020 | 02:42 PM
erin ellingsworth's Avatar
Default Key Fob Programming
I am needing to program a keyfob. I have an obdII and mongoose pro, does anyone know the exact software I need to load and do I have to do it in any specific order?
Old Sep 27, 2020 | 07:51 PM
motorcarman's Avatar
Carnac the Magnificent can "divine" unknown answers to unseen questions about MAKE MODEL YEAR!!!!!!!!!!!!!
Old Sep 28, 2020 | 01:14 PM
2010 XF Base Model
Old Sep 29, 2020 | 04:49 AM
Bigv's Avatar
You could take it to an auto locksmith along with your spare, good key
Old Sep 29, 2020 | 10:20 PM
that would be great if I could find one to do it
Old Oct 9, 2020 | 07:04 PM
Carlos Saez's Avatar
I had 1 key, got a OBDSTAR h100 from aliexpress, worked wonders, made a copy in 2 min.
Pretty straight forward.
Old Oct 10, 2020 | 01:20 AM
what mode and year do u own
Old Oct 11, 2020 | 08:04 AM
Mine is a 2010 xfr. I used type 1.
Old Oct 11, 2020 | 07:03 PM
2010 XF base model.
Old Oct 13, 2020 | 07:50 AM
2010 XF base model.
It will work on your car, here's a video on how to:
Old Oct 13, 2020 | 07:34 PM
https://youtu.be/NcxE7sso2fU
  • Awesome. Thanx bunches
Old Dec 15, 2020 | 12:43 PM
bealzabubba's Avatar
As the "proud" new owner of an OBDSTAR H100, and finally in possession of two keys for my '12, just wanted to say this worked as the video indicated.
No clue what else I'm gonna use that device for, but it was $80 less than the dealer wanted to program my new fob.
Old Aug 13, 2021 | 05:57 PM
Nyshadow's Avatar
Had a question, i know this is an old tread, but does the H100 add the new keyfob to the system or is it just copying the original key fob.
Old Aug 14, 2021 | 07:46 AM
thistle4celtic1's Avatar
Not exactly sure how it (re)programs the new key fob.
I made two “new” fobs using the OBDSTAR H100 and both needed a working key in close proximity to do so, so I’m assuming there is some “copying” involved?
First one I made from the damaged original I had and second one I made from the fresh fob I just programmed.
FWIW…One was made using a brand new “knock-off” fob and one using an original Jaguar fob that had been wiped clean.
Old Aug 15, 2021 | 11:33 AM
clubairth1's Avatar
Community Influencer
Yes those are key cloning devices which are different from the factory method of adding additional keys to the car. It can work well but they are just copies of the original key.
Old Aug 19, 2021 | 09:35 AM
gumby7734's Avatar
I used SDD to create a new key for 2009 xf supercharged.
Old Aug 22, 2021 | 06:54 AM
skyarrow's Avatar
My problem is this. The transponder within the key is working as I can start the engine, however before using the key to program it to the car I cannot make the car enter the key programming mode by flashing the head lights etc. The light on the J panel does not light up and the buttons on the key do not show any reaction from the car. Talking to Jaguar mechanics it is obvious that I seem to know more than they do gained from forums such as yours. Any suggestions.
Old Aug 22, 2021 | 08:42 AM
clubairth1's Avatar
You can't program keys with just the car. Needs SDD or some aftermarket device.
Old Aug 22, 2021 | 10:07 AM
John Williams's Avatar
The Autel AP200 says it can copy a good key & is a cheaper alternative than other options. You also get a quality 7 digit code reader with plenty of service options!
Joeaksa
Dec 31, 2018 11:48 AM
MR. CJ
Dec 28, 2014 06:13 PM
