key fob stuck in slot
Old Dec 16, 2020 | 02:43 PM
casualjohnson's Avatar
Default key fob stuck in slot
My car battery died and the key fob was stuck in the slot, which I understand because there was no electrical power to anything. But the battery has been replaced and the key fob is still stuck in the slot and the car won't start. How do you force the car to release the key fob? Usually I just press and release it. I have tried pressing it in and holding it and pumping the brake. I'm afraid this is going to be another major repair/reprogramming hassle and tow over something that should be simple.
Old Dec 16, 2020 | 07:10 PM
BritCars's Avatar
I'd start with a power reset. Disconnect battery terminal for one minute. Reconnect and see if you can then get it to come out
Old Jun 23, 2023 | 10:02 AM
geraldprins's Avatar
How did you solve this issue I’m currently having a similar issue
Old Jul 13, 2023 | 02:42 AM
Nosferatu's Avatar
I have the same problem.
Please help!
Old Jun 17, 2025 | 04:48 PM
Ribshurr's Avatar
we’re you able to solve it? If so mind sharing what you did currently stuck in the same predicament.
karenh
Sep 3, 2020 03:59 PM
George05
Aug 30, 2019 05:16 PM
XKGuy
Jan 27, 2015 02:42 PM
craigbfg
Oct 30, 2013 09:33 AM
taulpaul
Sep 15, 2013 10:50 PM
