Leaking tranny fluid 2010 XF
Old Mar 9, 2016 | 12:41 PM
trav2010xf's Avatar
Default Leaking tranny fluid 2010 XF
My 2010 XF is leaking tranny fluid. Picture attached is location of the leak (silver Bolt). What is this and common for tranny leak from here? Suggestions?
Old Mar 9, 2016 | 12:58 PM
Welcome to the forum trav2010xf,
I've moved your question from Jaguar Forums Feedback & Suggestion Center to XF/XFR forum. The Feedback & Suggestion Center is for posts about the forum and not for technical questions.
Members here with the same model will be able to help.
Old Mar 9, 2016 | 01:02 PM
NBCat's Avatar
The ZF 6HP26/28/32 series gearboxes are prone to leak from the pan and from the electrical connector sealing sleeve. If this is the case on your vehicle, the pan must be removed to allow access to the sealing sleeve.
bgreenback
Dec 10, 2020 10:48 AM
TexMurphy
Mar 13, 2016 09:07 PM
Mark1975
Mar 7, 2016 01:41 PM
xtypejag502
Mar 6, 2016 02:22 PM
catbug12
Mar 6, 2016 11:21 AM
