Media showing "No Signal"
Hello all, new here,
I am testing a 2012 5.0.
The media screen is displaying "No Signal" after startup. It does work when I engage Reverse, shows the camera and when I touch it I do get the menu. when going back to D, I get the same "No signal"/
Help, please.
Help, please.
Sorry for the bad suggestion! It may require a dealer visit to see if any codes are present.
Strange too since it does work (Play music) but the display does not show any media is present?
When I engage reverse the screen comes back and I can access the menu.
Any other gear I am getting "no signal" in a Blue box.
Yep a reset of the BCM may be required. I am waiting for the OBD cable to arrive.
Most likely to be the bluetooth unit - these are common failures, I think due to the position under the driver's seat, although mine failed with no obvious signs of water ingress etc.
You can purchase MOST bypass loops on amazon etc that will allow you to remove units from the loop in turn to find the faulty one.
kosta013
Mar 10, 2014 11:14 PM
