Media showing "No Signal"
Old Dec 21, 2021 | 07:26 AM
IlanLCD's Avatar
Default Media showing "No Signal"
Hello all, new here,
I am testing a 2012 5.0.
The media screen is displaying "No Signal" after startup. It does work when I engage Reverse, shows the camera and when I touch it I do get the menu. when going back to D, I get the same "No signal"/
Help, please.
Old Dec 21, 2021 | 11:24 AM
clubairth1's Avatar
Community Influencer
What do you have the media set to?
If I switch to sat. radio which I don't have a subscription for I get a no media message.
Old Dec 21, 2021 | 11:29 AM
IlanLCD's Avatar
I don't have sat.
It is playing music, just the screen showing "no signal"
Tried to reset it, can't.
Old Dec 21, 2021 | 11:57 AM
clubairth1's Avatar
Sorry for the bad suggestion! It may require a dealer visit to see if any codes are present.
Strange too since it does work (Play music) but the display does not show any media is present?
Old Dec 21, 2021 | 12:07 PM
IlanLCD's Avatar
When I engage reverse the screen comes back and I can access the menu.
Any other gear I am getting "no signal" in a Blue box.
Yep a reset of the BCM may be required. I am waiting for the OBD cable to arrive.
Old Dec 27, 2021 | 03:34 PM
dennis black's Avatar
TRY THIS
Old Dec 27, 2021 | 03:44 PM
IlanLCD's Avatar
Originally Posted by dennis black
You mean to add the Android box? If it will help, sure why not.
Old Dec 30, 2021 | 08:45 AM
IlanLCD's Avatar
Update, after scanning with SDD I got the U1A24-00 code. The MOST ring has no communication.
I need to find the defective unit,
Old Dec 30, 2021 | 01:54 PM
davetibbs's Avatar
Most likely to be the bluetooth unit - these are common failures, I think due to the position under the driver's seat, although mine failed with no obvious signs of water ingress etc.
You can purchase MOST bypass loops on amazon etc that will allow you to remove units from the loop in turn to find the faulty one.
Queen and Country
Jul 20, 2023 01:15 PM
Alex&Archer
Sep 7, 2019 03:03 AM
NigelPeck
Mar 30, 2018 09:38 AM
Hank Scorpio
Mar 1, 2018 09:09 AM
kosta013
Mar 10, 2014 11:14 PM
