Message Center
Old Aug 1, 2018 | 11:01 PM
Joe Glasson's Avatar
Default Message Center
2009 Jag XF Supercharged... Anyone know what "Restricted Performance" on message center is? Was on, then disappeared after a few miles.
Old Aug 2, 2018 | 03:50 AM
Welcome to the forum Joe,
I've moved your question from X260 (2015 onwards) to X250 (2007 - 2015) forum. This is the place to post technical questions about your model.
RP is well known with many Jaguar models but extraordinarily it is not even mentioned in the 2009 XF Driver's Handbook! When it happens, the engine is restricted to around 2000 rpm to 'prevent damage'. It is caused by one or more sensors recording an out-of-range reading. The only way to identify this is to have the DTC's (Diagnostic Trouble Codes) read.
Old Aug 2, 2018 | 07:53 AM
carzaddict's Avatar
Restricted Performance is a serious issue, the car is telling you something is wrong with the engine and it is limiting the power output as to not break anything. This is also commonly known as "limp home mode"
Get a code scanner or get the car to the nearest shop. do not drive it around
Black Cat
May 7, 2020 07:34 AM
jagpro69
May 23, 2009 09:34 AM
blackcloud71
Jan 21, 2008 04:41 PM
Nov 29, 2005 10:42 PM
