Message Center
Old Jul 11, 2009 | 05:14 PM
hlgeorge's Avatar
Did you check the rear fog lamps?
Also the brake lamps. The cruise function may be connected to the brake light switch.
Old May 1, 2020 | 05:03 PM
Bob Boyle's Avatar
Originally Posted by Black Cat
'03 XK8 just started a scrolling between "Cruise Control Unavailable" and "Check rear lights" Cruise doesn't work but all of the rear lights function properly.
Ideas?
Did you resolve this problem; mine has the same symptoms? If you were successful share what you did.
Thanks.
Old May 6, 2020 | 02:24 AM
Thanks.
Welcome to the forums Bob,
On the subject of sharing, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old May 6, 2020 | 02:27 AM
JagV8's Avatar
Thanks.
Near 11-yr-old thread so may not get a reply....
Old May 6, 2020 | 06:29 AM
RJ237's Avatar
Thanks.
The switch is actually two micro switches. One for cruise and the other for stop lights. So the cruise switch could fail and still have stop lights. Also the lever that actuates it could not be making contact, and need adjusting.
Old May 6, 2020 | 07:57 AM
giandanielxk8's Avatar
Thanks.
Brake pedal switch part number: LJB6420BB
There are lots of threads on swapping this part. It's behind and above the brake pedal. You will need:
  • A spanner or ratchet with I think a 10 mm socket
  • A flash light mounted on your head
  • If you are a big guy, contortionist skills or an 8 year old child.
Old May 6, 2020 | 09:42 AM
Jon89's Avatar
Rather than replacing the failed brake pedal switch assembly with a new one from Jaguar, you are much better off replacing just the two microswitches contained in the assembly. Decent soldering skills are required. I had a local EE friend do it for me after the new assembly I installed in late 2012 failed in late 2016....
This approach will cost you less than $15 (including shipping) compared to the $130 or more for a new assembly, and the replacement microswitches (one source is mouser.com) are better-quality than the OEM ones....
Old May 7, 2020 | 07:34 AM
SamtheSham's Avatar
After having a local shop replace the brake switch twice(in case 1st switch was bad), I took the car to local Jag dealer. They replaced the switch again, and 'check rear lights' went out, but still no C.C. Had to replace switch in the steering wheel. Now all seems o.k.
Orthodixie
Sep 16, 2017 09:13 AM
smith356
Feb 27, 2015 10:49 PM
Jim D
Jul 22, 2014 08:22 PM
Dlee
Jul 20, 2012 09:30 AM
jagpro69
May 23, 2009 09:34 AM
