metal bar that goes across the trunk under mat in xfr
Old Feb 11, 2020 | 05:49 PM
wimmer's Avatar
Default metal bar that goes across the trunk under mat in xfr
what is this and what does it do? trying to put in a speaker box and that couple inches prevents it from sliding all the way to the seat back
Old Feb 11, 2020 | 05:59 PM
John Williams's Avatar
Don't remove it, it stabilises the rear suspension, it's not just the xfr that has it fitted!
Old Feb 11, 2020 | 07:41 PM
wimmer's Avatar
thanks john
Old Feb 11, 2020 | 08:48 PM
OzXFR's Avatar
Yep, it's a rear strut brace.
Each end is bolted to the top of the strut tower via the existing bolts (four each side IIRC).
It's not REALLY essential, it just improves the handling of the rear end near the limit, more in keeping with the "sporting" nature of the XFR and other higher spec XFs.
If you never drive in this way and handling is a lesser priority to you than tunes than by all means go ahead and remove it, just some trim panels to unclip and move out of the way to access the mounting nuts then (IIRC) a 14 mm socket to undo the nuts.
Old Feb 11, 2020 | 09:00 PM
wimmer's Avatar
any idea what its made of? thanks oz
Old Feb 11, 2020 | 09:06 PM
OzXFR's Avatar
Pretty sure it is mild steel.
Old Feb 11, 2020 | 09:39 PM
wimmer's Avatar
oz how are the fires over there? I was in the Navy and went to Perth/ Fremantle back in the 80's and loved the place and the people.
Old Feb 11, 2020 | 09:54 PM
OzXFR's Avatar
Most of the fires are out, we have had lots of rain recently where the worst fires were.
Still lots of cleaning up and recovery to go.
Old Feb 11, 2020 | 10:05 PM
wimmer's Avatar
we have had a lot of fires California way but the rest of the stays its been rain and flooding, it all just sad
Old Feb 24, 2020 | 05:37 AM
DavidXFS's Avatar
Is this what you are talking about. I was wondering what it was...
Old Feb 24, 2020 | 03:56 PM
OzXFR's Avatar
Yep, that's it.
wimmer
Mar 27, 2021 03:09 PM
Chadly
Jan 24, 2014 04:08 AM
Escolar
Aug 11, 2012 08:17 PM
davidcalgary
Jun 22, 2011 08:45 AM
