Motul ATF VI a good substitute for the 8 speed ZF?
Old Jul 2, 2018 | 06:56 PM
10 XF Premium's Avatar
Default Motul ATF VI a good substitute for the 8 speed ZF?
Anybody used Motul’s ATF VI in the 8 speed transmission?
https://www.motul.com/us/en-US/products/atf-vi
Here is the spec sheet, 2nd page shows it is compatible for the XF Lifeguard 6/6plus/8.
https://s3-eu-west-1.amazonaws.com/m...pdf?1529067659
Dealer wants over $60 a quart for Jag branded fluid.
Old Jul 6, 2018 | 12:47 AM
ariba's Avatar
I am planning to buy ZF fluid
I just bought ZF trans filter for $96
Old Jul 6, 2018 | 09:47 AM
The dealer found a substitute for around $6 a quart. I will find out what they used and post up when I get it back.
Old Jul 6, 2018 | 11:12 AM
lotusespritse's Avatar
You can buy the ZF fluid from other sources for much less. Considering you change this fluid maybe once or twice in the life of the car, I wouldn't do anything to **** off the finicky ZF transmission.
Here it is at less than half that price:
https://www.roverparts.com/Parts/LRN13754ZF
Or buy it in a kit with the filter:
https://www.roverparts.com/Parts/TRANSM300SKA
Old Jul 6, 2018 | 01:13 PM
ariba's Avatar
I think are trans takes about 9 quarts
Old Jul 6, 2018 | 03:05 PM
Well then buy 9 quarts. Duh.
But you're wrong. I changed my XF filter and oil with this kit per the manual's instructions and I had enough with 7 quarts.
Old Jul 6, 2018 | 10:29 PM
I am not sure any of those “kits” are for the 8 speed transmission of the facelift XFs.
There are several XF Lifeguard fluids out there. 6, 6plus, and 8 from what I have found in 1 quick search.
I am not worried about “pissing off” the transmission, the Jaguar dealer found the fluid, performed the service and will stand behind the work as well as the CPO warranty covering everything for several more years.
I hope to have the car back on Tuesday and I will post up what fluid they used.
Old Jul 7, 2018 | 06:33 PM
Bigg Will's Avatar
Well Redline oil offers a 100% synthetic alternative (D6 Trans fluid) to the ZF synthetic blend for about $13 a qt. I've ran it in my XFR for 4 years (40kmi to 94kmi and counting) with no issues. Nothing magical about the ZF trans, why buy ZF's magically priced fluid.
https://www.redlineoil.com/d6-atf
ChrisJay
Nov 3, 2016 11:53 AM
scarbro2011
Jan 16, 2014 12:15 PM
iownme
Dec 9, 2012 06:49 PM
Wolfmiester
Dec 5, 2008 02:08 PM
SpartanX
Feb 17, 2008 10:41 AM
