Need Part number - long bolt supercharger lid
Old Dec 13, 2020 | 12:23 PM
Oxidizer2k's Avatar
Default Need Part number - long bolt supercharger lid
Trying to finish up the Car after replacing the supercharger coupler and as I’m putting the bolts back I noticed the long bolt seems to be damaged. (Long bolt towards the front of the lid) Can someone help me find the part number? I’m looking online but have failed to find it. I’m sure it’s a dealer only part or online.
thank you for any help
Old Dec 13, 2020 | 04:08 PM
davetibbs's Avatar
There's two of them, M8 x 150mm.
Part number AJ811189. Not expensive online, so probably wouldn't be the worst cost at a dealer.
Old Dec 13, 2020 | 06:30 PM
Oxidizer2k's Avatar
thank you so much!!!! I was doing terrible job searching and couldn’t find the proper wording. It was even harder without seeing a diagram on most sites.
Old Dec 14, 2020 | 12:39 AM
chris.schneider's Avatar
To me this looks like there are remains of the block's aluminum thread in that bolt. So its not your bolts that are damaged but the thread in the aluminum block. Maybe someone overtightened or did not start on the thread when re-inserting the bolt.
If I where you I'd clean the bolts with an iron brush or ideally with an M8 cutter, and then re-cut the thread in the block with an M8 cutter, too. Carefully located the thread when putting the bolt back. Then tighten the bolts with 25Nm. You should be safe if the torque meter triggers. If it does not, you can put in a heli coil or use a similiar thread repair kit.
Chris
Old Dec 14, 2020 | 12:03 PM
Oxidizer2k's Avatar
Chris
Chris, you won’t believe how much force I had to use for many of the bolts. It almost felt like an impact was used to tighten them. Who ever worked on the car before I owned it definitely did not use torque specifications.
Old Dec 14, 2020 | 12:47 PM
davetibbs's Avatar
Ouch. These aluminum blocks do not take kindly to that - hopefully they haven't mangled any fine-threaded holes (e.g. water pump)...
Old Dec 14, 2020 | 01:19 PM
Oxidizer2k's Avatar
It’s usually how it goes after buying a used car.. all these surprises are waiting to be found. Luckily this is the only issue I’ve had with a bolt.
Old Dec 14, 2020 | 06:26 PM
kansanbrit's Avatar
Clean the threads and reinstall, will almost certainly be fine.
Old Dec 14, 2020 | 06:27 PM
kansanbrit's Avatar
Probably just corrosion.
Old Dec 24, 2020 | 09:59 PM
Oxidizer2k's Avatar
Got the new bolt and it went in smooth. Luckily just the old bolt threads were bad.
scz4
Oct 28, 2020 03:07 PM
harvest14
Jul 30, 2019 07:35 PM
mehauto
Sep 30, 2018 01:17 PM
jnasios
Jul 25, 2018 10:57 AM
Holy F type
Apr 18, 2017 10:04 PM
