New battery/alternator "battery not charging"
Old Dec 14, 2018 | 03:04 PM
So Charlie's Avatar
Default New battery/alternator "battery not charging"
In my case after all the headache it turned out to be the little *** single wire that comes off the positive battery line held down by a single nut on top of the post.
Old Dec 15, 2018 | 09:16 AM
Brutal's Avatar
well you figured it out. I was going to say you need to check that wire, it has a fusible link in it. It always gets blown when people jump start a car with battery cables and get careless . if the cable clamps bite into that wire when hooking up to the battery you just provided a short to ground and there goes the fuse. seen many independent shops replace alternators because they don't know the car and the owners are out a lot of money needlessly for a $5 replaceable link. then they come to us cause its still not charging and we replace the link.
Old Feb 10, 2020 | 03:20 PM
Skeggylad's Avatar
Default Battery charging
hi, could you tell me where this wire is as I am having the same problem now? Thankyou.
daholmes
Jul 12, 2018 09:22 AM
Gophat
Dec 11, 2017 04:49 PM
kashaf
Nov 7, 2013 08:31 AM
yaron369
Apr 30, 2013 02:42 PM
Willchill
Jan 18, 2011 08:39 PM
