Noise on morning Cold startup? [clip]
Old Feb 2, 2019 | 01:31 AM
hen555's Avatar
Default Noise on morning Cold startup? [clip]
So on my morning startups I’m hearing a weird noise from under the hood. I recorded it and uploaded it , any idea what it is and if it’s serious? Yesterday it was even colder and the noise was different sounded like a whistle/whine that went away after a couple of seconds changing in pitch.
I have been told my engine burns oil based on somone saying they saw smoke from my exhaust on startup. Could the noise be the engine burning oil ? Or is it a leak? I checked my oil level and it’s OK
I haven’t changed my engine air filters in a while I think they are due.
Old Feb 2, 2019 | 10:07 PM
Bigg Will's Avatar
From the clip it sounds like the timing chain?
Old Feb 2, 2019 | 11:59 PM
davetibbs's Avatar
I'm inclined to think so too - try and get someone to record you start it while they're standing over the engine with the hood up so we can get a better listen to it. Let it idle for 20-30 secs and keep recording too
Old Feb 3, 2019 | 12:30 AM
mrNewt's Avatar
Yeah, you cut the video way too short...
Old Feb 3, 2019 | 02:25 AM
hen555's Avatar
I think there may be 2 sounds going on here. There’s one thump sound at initial ignition and the other is a clicking sound.
I recorded another video today in the garage with not as cold but still sub freezing temperatures. No thump sound this time.
Old Feb 5, 2019 | 07:49 PM
lotusespritse's Avatar
How many miles on the car?
Old Feb 5, 2019 | 09:06 PM
mrNewt's Avatar
Don't know these engines myself too well, but too me is sounding like an external (outside the engine) noise... maybe a bad pulley!?
I mean I hope for you...
To more experienced people out here... do these engines have a hydraulic chain tensioner?
Old Feb 5, 2019 | 10:58 PM
OzXFR's Avatar
Yep, two of 'em, one on each bank.
Quote from page 56 of the AJ133 Technical Training doc:
"Each camshaft chain has a spring-assisted hydraulic tensioner operated by engine oil pressure. The chain tensioners also incorporate a ratchet mechanism to eliminate start-up noise. The chains are lubricated via oil squirt tubes located at the front of the engine block. Nylon chain guides control chain motion on the drive side."
Get yourself a copy of this doc from my Dropbox here: https://www.dropbox.com/s/8y4iax9hm2...%20V8.pdf?dl=0
Wear on those tensioners and their guides is a common and well known problem, when worn they rattle quite a lot, a few threads/posts around here on the topic. Here's one: https://www.jaguarforums.com/forum/x...-techs-159928/
Old Feb 5, 2019 | 11:30 PM
mrNewt's Avatar
@OzXFR - Thanks for that document!
@hen555 - That might be your issue then!? Reading trough the thread that OzXFR posted, kind of hints to that.
That ain't a cheap fix that's for sure... do you know any good mechanic that could help with diagnosing this and help you fix it?
imageoftheson
Dec 12, 2017 11:40 PM
nelsonht
Feb 15, 2016 06:15 AM
AlbBolivar
Jun 19, 2014 10:40 PM
Prowler
May 6, 2010 02:06 PM
skanoski
Dec 22, 2008 04:23 PM
