Open trunk with dead battery
Old Mar 9, 2022 | 09:41 AM
dancemom's Avatar
Default Open trunk with dead battery
Hi everyone,
My car is at the mechanics with a dead battery! Is there a way to open the trunk to charge the battery? Apparently the key won't work to open it?
Any help is great.
Old Mar 9, 2022 | 10:50 AM
2018XF25T's Avatar
This is a different YM (X250). You have posted it on a X260 forum. Anyways,I hope this process help you open the trunk?
Old Mar 9, 2022 | 10:56 AM
I've moved your question from X260 to X250 forum. Members here with the same model will be able to help.
Old Mar 9, 2022 | 11:26 PM
dancemom's Avatar
Thanks Graham, I put it in the wrong place again. I appreciate you.
Kimberly
Old Mar 9, 2022 | 11:32 PM
dancemom's Avatar
Default Thank you very much
https://www.youtube.com/watch?v=ufokLEDexbo
Big thanks. I got it sorted.
Old Mar 11, 2022 | 10:59 AM
clubairth1's Avatar
Community Influencer
Can you post how it was fixed so it will help others in the future with the same problem?
Old Mar 12, 2022 | 09:15 AM
dancemom's Avatar
Hi Clubairth1, there is a video in this thread that I followed. It sorted it out. Let me know if you can see it.
Kimberly
Old Mar 12, 2022 | 11:31 AM
clubairth1's Avatar
Sorry no video that I can see?
Thanks for replying too.
Old Mar 12, 2022 | 10:15 PM
dancemom's Avatar
Hi, again.
I don't know how to share the video, but this the link.
Please let me know if it works.
** EDIT Also you can use the skeleton key in your key fob and access the key hidden key hole (behind a small piece of paneling, the size of a silver dollar) on the trunk where you press the release to open trunk usually. Your skeleton key will open the trunk here. I tried to find a video but could not.
Please let me know if this helps.
Kind regards,
Kimberly
I
Old Mar 13, 2022 | 10:19 AM
clubairth1's Avatar
Yes I can see it now. Note that if you have an XJ it has no external key lock for the trunk like the XF does.
Old Mar 14, 2022 | 06:42 AM
chris.schneider's Avatar
Instead you could just use the emergency key from your remote to pop open the trunk. The lock is hidden under a small piece of black plastic just next to the reverse camera,
Chris
Old Mar 14, 2022 | 09:34 AM
Six Rotors's Avatar
All this is described in the XF Owners Manual!!! It even has pictures.
Xeno
16
Sep 3, 2021 08:38 PM
bobhoff
Sep 29, 2018 08:14 AM
jrelrod
May 9, 2018 02:59 AM
Lommi
Jul 8, 2017 01:52 PM
gagman66
Jan 19, 2017 07:46 PM
