Power seats will not slide all the way forward
Old Apr 23, 2018 | 07:35 AM
robbro9's Avatar
Default Power seats will not slide all the way forward
Hello all, first post here, did a quick search and didn't see this specifically but I may have missed it, anyway, here it goes.
I have a 2013 Jaguar XF and a very short wife. Took the car in for a brake job and when we got it back the seat was all the way back. Problem is it will only slide about half way forward now. Naturally she sits up very close to the wheel, and while I'm taller, it wont even get close enough for me to use comfortably now either. The seat seems to move fine forward/back/up/down etc... and does not struggle, bump or hum, it just stops going forward much sooner than it should.
Its probably some auto stop thing or something I'm sure, what is my best way to reset/correct?
Thanks for any help!
Old Apr 23, 2018 | 09:49 AM
Welcome to the forum robbro9,
I've moved your question from General Tech Help to X250 forum. Members here with the same model will be able to help.
Old Apr 23, 2018 | 02:27 PM
Jag#4's Avatar
Be sure and check to make sure nothing is in the seat tracks (rails). It may just be something that has fallen in and obstructing the travel.
See if the seat is loose, meaning you can wiggle it by grabbing the seat back. The screws holding the tracks may not be tight and causing the obstruction.
Both are simple, non-auto shop things. Always check the easy stuff first if you haven't already. Can't think of another reason for stopping too soon. My XK had a screw rod that controlled travel and it is likely the XF does as well.
Old Apr 23, 2018 | 02:55 PM
There's lots of information on seat faults in the Workshop Manual.
Going through it confirms that seat travel is controlled by Hall Effect Sensors. These are known to be prone to faults from physical damage or even just getting dirty.
One of the first tests, before having to resort to a scantool to check for error codes is 'stall detection':
Try this technique and see if you can get the seat to inch forwards.
Attached Thumbnails Power seats will not slide all the way forward-stall.jpg
Old Apr 24, 2018 | 06:50 AM
robbro9's Avatar
Thanks, continuing to push the button forward a few seconds worked. Seems simple, but not knowing I never tried, so glad there was a simple trick to fixing this!
Old Nov 22, 2022 | 11:56 AM
Johnny Vig's Avatar
GGG, thank you for your post. I was able to follow what you posted and it worked perfectly. That's why car forums like this one are so awesome. Thank you so much!
Old Nov 22, 2022 | 04:59 PM
karamayoko's Avatar
People like GGG just makin life easier for ALL of us! truly the best Mod out there. Everyone can use a good person like GGG in their life lol his spouse must be lucky!
JensenHealey
Oct 24, 2016 12:48 AM
EJ Garity
Aug 17, 2015 12:09 AM
Eric Hopper
Jul 18, 2015 05:55 PM
harmonica2
Nov 18, 2014 02:25 PM
TomP
Apr 9, 2013 11:14 PM
