Random alarm and battery drain
Old Sep 6, 2025 | 03:58 PM
Leon57's Avatar
Default Random alarm and battery drain
Hi,
My 2.2D 2012 XF has random alarm going off when locked, both single and double locked. I have bridged the plug into the bonnet switch and there is no bonnet open warning signal anymore. The battery is new and is being charged as normal when running. Battery voltage after a short while not running is under 12V.
I've tried using my infra red heat thermometer on the fuses but as yet it doesn't seem to detect any warm fuses. This is after I open drivers door and boot and leave for 33 minutes minimum to make sure it has shut down.
I've locked it and put keys inside the house and tried the boot and doors and they stay locked so I believe the door and boot locks function as they should. I live in an isolated part of Australia many miles from any Jag dealers.
My wife wants me to sell it as she has lost faith in its reliability.
Any advice on where to next?
Cheers,
Noel
Old Sep 6, 2025 | 09:50 PM
dennis black's Avatar
20 Year Member
one of your door locks could be bad or hood latch
Old Sep 6, 2025 | 10:22 PM
Leon57's Avatar
Thanks but the switch to the bonnet has been bridged and doors won't open with the car locked and fob not within signal distance. So I've eliminated ( I think) the doors and bonnet).
Old Sep 8, 2025 | 10:19 AM
clubairth1's Avatar
Community Influencer
I think for something like this the Jaguar SDD setup is what you need. I see your a long way away from any dealer so not sure that suggestion will help you.
Old Sep 8, 2025 | 12:27 PM
Vasara's Avatar
Like Dennis black already wrote: One of your door lock is playing up. Microswitch inside of lock mechanics sensing the locking state or wiring to the door handle sensor/switch are most common reasons for false alarms with battery draing. The vehicle systems start wake up process every time door sensors are operated, even the locking state is not changed. Very commonf issue on XF.
Old Sep 8, 2025 | 04:27 PM
Leon57's Avatar
Thank you. If the locking state is still functioning, how do you isolate which door? With key fob away from car, doors won't open.
Old Sep 8, 2025 | 05:08 PM
Vasara's Avatar
Do you have or do you know anybody near you having an factory diag tool SDD? By that its possible to check what caused last alarm (if i remember correctly...) Other way is to try to replicate an false alarm by taping each door by hand. (may take lot of tryes and it might still be wrong door)
Old Sep 13, 2025 | 07:06 PM
Leon57's Avatar
I've isolated the drain to Fuse 23 in the passenger compartment fuse box. It seems to only control the centre console switches as I can access the radio via the steering wheel buttons. There is a noise behind the dash every 45 sec with the fuse in place and no noise or drain with the fuse removed. There is much confusion as to the correct fuse diagram as it appears the fuse box diagrams I can find have different functions for different fuses.
Old Sep 14, 2025 | 01:57 AM
Vasara's Avatar
What kind of noise? A fan running? -> there is an cooling fan on infoteinment system module.
Also check if the noise is actually coming from engine bay. (injectors make high pitch sound)
By factory diag tool (SDD) there are an fuction "Vehicle reset" what have been working for many clitches. (disconnecting of battery dosent reset modern vehicles with solidstate memory CAN bus nodes)
Old Sep 14, 2025 | 05:22 PM
20 Year Member
The sound your hearing is probably your ambient temperature sensor, check that ,you can disconnect it, like o said before double check doors also sun visor lights they could be on also
Old Sep 14, 2025 | 07:22 PM
Leon57's Avatar
Thanks. I've disconnected the rotating vents and the noise stopped. The 1.4 amp drain stopped until I reconnected a rotating vent and now it is still draining, even after I disconnected it again, although the noise stopped. The vents open and close as expected.
Does the SDD tool connect to my laptop and can I buy a stand alone unit?
Old Sep 14, 2025 | 07:25 PM
Leon57's Avatar
Thank you I'll look at those suggestions. Noise stopped after I disconnected rotating vents.
Old Sep 15, 2025 | 10:09 AM
Vasara's Avatar
Well done!!
At least you found the issue. Not absolutely sure how vent motors work by detecting the ends of their track? By microswitch or are they stepper motors what needed calibration for the track ends? Any forum member have correct info?
Maybe some of these have been replased and not calibrated -> Motor keep pushing against stopper?
Sorry i cant help on this.
SDD is an diag software what is installed on windows laptop. You also need suitable USB to OBDII port cable, like Mongoose, for vehicle connection.
Software itself is free to download but using it needs registration for JLR TOPIX service. (internet connection)
(some say that there are p*rate versions available from various wepshops in interweps what dosent need TOPIX connection)
Old Sep 23, 2025 | 04:42 AM
Leon57's Avatar
I've tracked it to a faulty circuit board in the ATC/HVAC module, it sits behind the centre console switches. I now have to track down a replacement.
Old Sep 23, 2025 | 10:03 AM
clubairth1's Avatar
Great results!
Can you fill in how you determined it was that board? Just to help the next guy?
Old Sep 23, 2025 | 04:02 PM
Leon57's Avatar
Default Explanation
I had determined Fuse 23 was supplying power to the battery drain by trial and error. I asked ChatGTP and it suggested an actuator in the HVAC system. I ordered a scan tool icarsoft V2 and when it eventually arrived it showed fault code B1088-88. ChatGTP told me that meant LIN Bus "B"-Bus-Off/Power #2 circuit problem. It said LIN B handles specific modules such as vent actuators and climate control. It then provided me with a comprehensive check list to determine what the cause may be and suggested I test the automatic temperature control module. It showed me how to access the ATC behind the centre console switches and provided a technical rundown of testing with a multimeter. Once I had the centre console switch panel out,I bypassed all the testing and simply removed the back panel and immediately detected the green corrosion on the circuit board. I'm not convinced that is the end of the problem but will source another temperature control etc switch panel. Once it's in hopefully my problem will disappear.
I've used ChatGTP several times in tracing the battery drain and have been impressed. For example it initially provided me with a PDF comprehensive check list for tracing the battery drain on the Jag XF. It is not infallible of course but has been invaluable in getting me organised and pointing me in the right direction.
Old Sep 24, 2025 | 07:54 AM
clubairth1's Avatar
Good luck with that AI!
I use the forums instead.
Old Sep 24, 2025 | 04:06 PM
Leon57's Avatar
I use forums as well but every bit of advice is subject to people's personal experience. AI can take a wide scan of advice and summarise it. I then have to use my discretion to work out my next move. It is only a tool. I use FB forums as well Jag forums, there is a lot of knowledge out there and also words of encouragement.
Lotus26R
Dec 5, 2020 02:47 AM
MrPeaks
Sep 17, 2019 03:33 PM
pcpilot
Apr 5, 2013 01:50 AM
aprilneo
Feb 8, 2013 07:48 AM
gudcat
Jan 23, 2012 06:46 AM
