Rear axle leak please help!
Old May 2, 2015 | 08:10 PM
brettzky13's Avatar
Default Rear axle leak please help!
Hello all, I do not post often but read lots on here. I have seen that SOME of the 2009 rear diffs were recalled seems like that recall ended in March 2011…..Me passenger side rear axle seal has started to leak…..I would like to just replace the seal but wanted to weigh in with some pros on jags as this is my first one.
I did buy the car from a dealer and they said nothing about the recall so I would think that if my car had the issue it would have happened long before now…….
Repairing the rear seal…..how many "special" tools are required to do this repair?
Thanks in advance
Brett
Old May 2, 2015 | 08:32 PM
brettzky13's Avatar
Sorry just looked to double check and it is only the driver side axle seal that is leaking…..
Old May 2, 2015 | 09:11 PM
NBCat's Avatar
The revised differential and axles are designed to remedy the issues with leaks and bearing wear for a certain VIN range. Any Jaguar agency is aware of the VIN range and would uprate the parts as needed should your vehicle fall within that range.
While there are seals available, it may be best to replace the differential and axles with the later parts so there is no need to repeat the repair.
Old May 2, 2015 | 11:44 PM
chuckh007's Avatar
NBCat……my 09 XF-SC has just recently exhibited a vibration or soft rattle from the rear when I am starting up or moving at about 10 mph and after that no odd sounds. This vibration is subtle and if you move fast enough you hardly notice it, but when crawling in traffic at around 10 mph it is reproducible every time. Any ideas ?
Old May 3, 2015 | 05:57 AM
larryorgnist82's Avatar
Anybody know the vin range that is affected?
Larry
Old May 3, 2015 | 07:33 AM
brettzky13's Avatar
VIN range would be great this is something i have not been able to find as of yet……When they replace the seal do they also replace the carrier barring at the same time or just pull the axle and replace the seal?
If my big cat does not fall in the recall I am considering doing this repair on my own, I have much experience with other types of vehicles, is there any "special Jaguar tools" required to do this repair?
Old May 3, 2015 | 07:53 AM
NBCat's Avatar
The VIN range can be provided by any Jaguar agency as the document listing the procedure by JLR is JTB00175NAS5 - Rear Differential Replacement.
You can also directly contact Jaguar and provide your VIN, or go to TOPix and insert your VIN to see all relevant items for your vehicle.
Old May 3, 2015 | 08:01 AM
brettzky13's Avatar
Can you provide a link to the web site where we can check our VIN……..
Old May 3, 2015 | 08:27 AM
NBCat's Avatar
www.jaguartechinfo.com
Old May 3, 2015 | 08:33 AM
NBCat's Avatar
It can be caused by many things, such as a tyre with a belt separation or even a flat spot.
Check the suspension components for tightness and wear.
Old May 3, 2015 | 10:59 AM
brettzky13's Avatar
NBCat - I ran my VIN in the provided webpage and the document number you gave me does not show up in the activity stream which I'm guessing means no new rear diff on the house for me?
Old May 3, 2015 | 01:48 PM
chuckh007's Avatar
Here you go…..check the VIN range on above bulletin. For XF(X250) it is R00001-R41865
That is the last 6 digits of the VIN. This is from JTB00175NAS5
Old May 3, 2015 | 04:15 PM
NBCat's Avatar
If your VIN is outside the range, it will not show. So, yes, JLR most likely are not going to replace the differential under that campaign.
Old May 3, 2015 | 05:18 PM
brettzky13's Avatar
My VIN ends R32689 which would suggest I am in that range……Anyway you can take a screen shot and send it to me?
Old May 4, 2015 | 01:21 AM
chuckh007's Avatar
give me your E-mail address.
Old May 4, 2015 | 05:17 AM
brettzky13's Avatar
b_jessop_13@yahoo.ca
Thank you Chuckh007 did you get this info off of jarugrtechinfo.com?
Old May 6, 2015 | 06:39 PM
brettzky13's Avatar
Well my big cat goes in to get looked at next Wednesday……They have acknowledge they have had issues in the past when shaft wears a groove from the seal in it……They also said it will be very costly for me to repair……sure hope this document Chuck sent me helps out
Old May 14, 2015 | 07:55 PM
brettzky13's Avatar
Well Diff is done as i suspected……..im trying to get Jag Canada to assist some how but have had no luck yet……used 2009 XF with low KM might be for sale soon to someone willing to put a diff in it…...
Old May 14, 2015 | 09:15 PM
jagular's Avatar
My friend who bought my "09 took her car to her favourite Ford dealer who had no trouble finding a replacement seal and fixing her Jag diff for a modest cost.
This diff was used in a lot of North American product and is a Dana diff so try that.
Old May 20, 2015 | 06:08 PM
brettzky13's Avatar
SOOOOO today i was told that YES Jaguar did recall this issue in SOME cars but the technical bulletin they have does not match my VIN…….HOWEVER Chuck was so kind to pass along a technical bulletin that DOES have my VIN number on it……….Im still fighting hard for this repair and should have a final answer by Friday at the latest I'm told……
