Rough idle
Old Jul 30, 2017 | 02:32 PM
Daniel Salazar's Avatar
Default Rough idle
Sounds like a vacuum leak comming from the intake manifold. Any vids or pics on intake manifold removal?
Old Jul 30, 2017 | 04:38 PM
croco's Avatar
Can you please describe the problem further?
I'm getting a jumpy idle. My tach needle keeps jumping between 400-600 rpms at idle but no codes or check engine light. I am suspecting MAS to be dirty and i am going to clean that.
Just wanted to see if you have something of similar nature or if you are getting a Check engine light or any sort of warnings on the dash
Old Jul 30, 2017 | 06:05 PM
davetibbs's Avatar
OP - what car/engine do you have?
Old Jul 30, 2017 | 07:34 PM
Check engine light is on. Around 4-600 rpm range is the same.
Old Jul 30, 2017 | 08:24 PM
croco's Avatar
I'll be following your thread. mine has the idle surge but no Check engine or any warnings.
What size motor and model your car??? Do you get a burning oil smell at hard/full throttle accelerations? Mine has that smell and I am yet to find out where it is coming form.
Old Jul 31, 2017 | 12:46 AM
JagV8's Avatar
Read the codes. Get an OBD tool with live data so you can diagnose it.
Old Aug 2, 2017 | 08:35 PM
Shadow993's Avatar
Mine had 2 issues.
1. Vacuum tube on top supercharger valve
2. Bad coil
I was getting misfire codes at start-up idle .
Old Aug 4, 2017 | 12:10 PM
Shadow993's Avatar
